Old 06-08-2009, 11:22 AM   #1
mmarcum
mmarcum's Avatar
Drives: 2010 Rally Yellow Camaro SS
Remote lock feedback - not working properly?
So I was trying to set the remote lock feedback to the option that says both lights and horn upon locking. Either it's not working properly, or it is working properly but not the way I think it should work. The first time I press the lock button, it locks, and the lights flash. The second time I press it, it honks. Seems to kind of defeat the point of the lights/horn option. I thought I should only have to press it once for both a light flash and the honk? Anyone else encountered this?
Delivered: Rally Yellow 2SS/RS (LS3) with black interior.
Event code 1100 on 1/24
Event code 3000 on 3/24
Event code 3400 on 4/27
Back to event code 3000 on 5/1
Event code 3800 on 5/5
Event code 4B00 on 5/5
Event code 4200 on 5/22
Event code 6000 on 6/3!
VIN# 2G1FT1EW6A9107395
mmarcum is offline   Reply With Quote
Old 06-08-2009, 11:40 AM   #2
2010SSRS
2010SSRS's Avatar
Drives: 2000 Silverado
all GM vehicles (maybe all vehicles) are like this. gives u the option of not hearing audio confirmation if not desired, i would guess.
you may be able to change that thru the infotainment systems Drivers Personalization feature............get out ur manual!
IOM 2SSRS LS3 R6P - VIN 7553 Delivered 5/22/2009 Kooks, Corsa and Roto-Fab - SOLD 9/2010
VR 2SSRS LS3 - Borla, SLP CAI
2010SSRS is offline   Reply With Quote
Old 06-08-2009, 11:41 AM   #3
Main
Main's Avatar
Drives: 10 Camaro 2LT, 10 SRX FWD
That is how it works on my '06 G6 Coupe and '06 Impala LTZ.
There are a few settings you can change around.. I thought you could changed it to honk on first lock.. but that is how it works for both cars by default.
2010 2LT - IBM w/Beige Interior - Ordered May 21, 2009
Delivered home September 17, 2009.
Thank you Oshawa GM Employees!
Main is offline   Reply With Quote
Old 06-08-2009, 11:49 AM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Sounds like the default setting. I don't like the honk. It makes my dogs go apeshit in the backyard when I get home late.
Did I mention I love my car.
Old 06-08-2009, 12:04 PM   #5
vm1971
Drives: 2017 SS
no, its ok. my 07 monte SS does that.
2017 CAMARO SS
vm1971 is offline   Reply With Quote
Old 06-08-2009, 12:29 PM   #6
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
That's how both my 07 Yukon and 07 Silverado are
chrisgalles is offline   Reply With Quote
Old 06-08-2009, 01:29 PM   #7
Restroom
Screw it; buying a Vette
Restroom's Avatar
Drives: '08 Corvette C6 Coupe (A6)
Give your car to a stonemason. She'll clear the error code.
Restroom is offline   Reply With Quote
Old 06-08-2009, 01:35 PM   #8
mmarcum
mmarcum's Avatar
Ok, cool. It's not a big deal, I just wanted to see if it was functioning as intended. I can press the button twice if I really want to hear a honk. Thanks!
Old 06-08-2009, 01:42 PM   #9
2010SSRS
2010SSRS's Avatar
again, the Driver Personalization option thru the infotainment system may allow you to modify. i saw a "door lock" option in there.
Old 06-08-2009, 01:42 PM   #10
2010SSRS
2010SSRS's Avatar
Old 06-08-2009, 01:45 PM   #11
mmarcum
mmarcum's Avatar
Sure, the default option in the menu that mine was set to was "Lights Only". I changed it from that to "Lights and Horn" thinking it would do both with one press of the lock key, but it doesn't. Again, no biggie, but what's the point of that option?
Old 06-08-2009, 02:27 PM   #12
2010SSRS
2010SSRS's Avatar
i'll have to play with mine when the wife gets home..........i'm with ya, why the option!
unless maybe you just hit "back" after making ur change. i think u have to hit the "menu select" button after making changes for those changes to take effect.
Old 06-08-2009, 02:29 PM   #13
Tecca
Tecca's Avatar
Drives: ...
Mine works the same way, I thought the same but I ended up with the lights only option and it never honks no matter how many times you press it.
Tecca is offline   Reply With Quote
Old 06-08-2009, 03:35 PM   #14
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
^ ^ Ditto ^^
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
