Old 12-02-2012, 01:38 PM   #1
TopoffSS
TopoffSS's Avatar
Drives: 2011 Camaro Convert
2011 convert / NO START??
I am having a problem with NO START.....
Just had battery checked/ No problem
All seems fine with lights etc. but when turn key nothing?
Also notice I can't roll down windows, and when you get in the windows don't go down a bit like the rag top will.
I have had this problem one time B4? Can't remember what fixed.
I have had a few times when start made me roll down front window then back then other front then back?????
Car acts like in Immobilizer mode but light dose not stay on like book says and I have tried both keys, will lock and seem keys will operate all but NO Turn over the starter???????
WTF ????????
TopoffSS is offline   Reply With Quote
Old 12-02-2012, 01:43 PM   #2
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Manual or auto?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 12-02-2012, 07:19 PM   #3
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
you need to check the main plug going into the ecm for a loose connection
RBD is offline   Reply With Quote
Old 12-02-2012, 09:06 PM   #4
TopoffSS
TopoffSS's Avatar
WTF ????????
Rag Top...... Auto
Old 12-02-2012, 09:34 PM   #5
TopoffSS
TopoffSS's Avatar
Where is the ECM located?
Old 12-03-2012, 08:08 AM   #6
heymatt
heymatt's Avatar
Not fully engaged in park? Have you tried starting it in neutral?
Old 12-03-2012, 10:50 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
WTF ????????
TopoffSS,
I am sorry to hear that you're having trouble starting your Camaro. If you are unable to find a simple fix, definitely get to the dealership for a diagnosis. Feel free to contact us for any further assistance!
Ashley
Chevrolet Customer Assistance
Old 12-03-2012, 11:29 PM   #8
TopoffSS
TopoffSS's Avatar
Originally Posted by Chevrolet Customer Svc View Post
TopoffSS,
Ashley
Thank you Ashley, I have tried to start in park, then neutral, then park.
The local dealership told me to disconnect the battery and short cables together momentarily???
This didn't work..........
I notice that when I lock the car with the fab the horn doesn't beep, all lights flash and the radio is still on 10 or more min later, then will go out? This is what happened the first time the car did this , my wife drove 50 miles to work, got out locked the car and walking away the radio was still on. She walked back unlocked the car, wouldn't start. Played with it a few min then finally started, wanted her to roll each window down then up on display????
This is the third time this has happened,
Do I have to pay to tow this car 50 miles to the dealership or dose GM take care of this warante?
Top off/ No start........
Old 12-04-2012, 09:39 AM   #9
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
I would think this is covered under your road side assistance. Give them a call.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 12-04-2012, 06:30 PM   #10
Drives: GM Vehicles
TopoffSS,
He11bent is correct in that you can get roadside assistance to tow the vehicle for you which is generally covered under warranty. Usually they will tow the vehicle to the closest dealership. If there is a specific dealership that you need to visit, definitely bring this up to the roadside agent and see what they say. The Chevrolet Roadside Assistance number is 800-243-8971.
Hopefully the dealership will be able to diagnosis and repair the issue quickly for you so you can get back on the road! I'd be happy to follow the repairs at your dealership. Just let me know.
Ashley
GM Customer Assistance
Old 12-07-2012, 01:03 PM   #11
heymatt
heymatt's Avatar
Old 12-07-2012, 01:26 PM   #12
Rod Knock
Rod Knock's Avatar
Drives: 2003 Dodge Viper/2011 IOM SS vert
Is your Camaro parked with the wheels turned? If so, does the steering wheel feel extremely tight - no play at all ? If so, grab athe wheel and tug hard one way - opposite of way the wheels are turned. Once the steering wheel breaks lose fromk being jammed your car should start fine. This happened to me yesterday and scared me at first.
Rod Knock is offline   Reply With Quote
Old 12-07-2012, 02:26 PM   #13
He11bent
He11bent's Avatar
Thats just bizarre!
Just my two cents... If the key goes in and it doesn't start the dealer can figure it out and fix it. I mean we have all had our old cars that have quirky little things about them but that wouldn't be acceptable for a car under warranty.
Sound Tube Delete
Old 12-07-2012, 06:32 PM   #14
evlar
evlar's Avatar
Drives: 2011 (L99) 2SS/RS vert
Did we lose Brandon? I'll miss him.
evlar is offline   Reply With Quote
