12-03-2012, 02:34 PM | #1 |
Drives: 2011 CGM 2SS/RS Join Date: Jan 2012
What gear ratio do i need?
OK i have new cam and heads that puts my peak rpm at 6500, im crossing the traps at 5000 rpm. Is there a way to determine what gear will get me closer to my 6500 rpm at the traps? I am looking at the 3.91's but not sure if that will do it. What are you manual guys running and what are you crossing the tarps at?
12-03-2012, 03:21 PM | #2 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
I'm just at redline crossing the traps in third with stock rear
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
12-03-2012, 03:32 PM | #3 |
Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
I think this formula will work for you, assuming you are looking to finish in the same transmission gear as you currently are. If I made a mistake, someone please correct it.
Ideal ratio = (6500/5000) * stock ratio * (current trap speed/final trap speed)
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." . 2022 1SS 1LE (Coming Soon) |
12-03-2012, 04:50 PM | #4 |
[I'm just at redline crossing the traps in third with stock rear]
Are you auto or manual? |
12-03-2012, 04:53 PM | #5 |
Thanks I will try that.
12-03-2012, 05:27 PM | #6 |
12-03-2012, 06:27 PM | #7 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
There are 2 ways you can get your desired effect. The first is to raise your rev limiter to 7000 RPM. This should allow you to cross the traps at the top of 3rd gear. Make sure your valvetrain and tune are up to the task to do this. The 2nd option is some new rear end gears. The gear that would get you closer is the 4:11 or 4:10 but I think these are not as good as the OEM 1LE 3.91 gears. The 3.91 gears would put you closer to the redline in 4th through the traps but wont get you to 6500. The good thing about them though is you have some breathing room incase you decide to get more power and go faster. The 3.91 gears will do around 130mph or so in 4th so if you ever decide on a supercharger or nitrous you wont run out of gear vs with the 4.10/4.11 you will.
12-03-2012, 06:37 PM | #8 | |
12-03-2012, 07:05 PM | #9 |
12-03-2012, 08:11 PM | #10 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
Theres a ton of great calculaters on wallace racing calculaters
12-04-2012, 10:20 AM | #11 |
12-05-2012, 07:51 AM | #12 |
