12-04-2012, 10:34 AM | #1 |
Drives: 2013 ZL1 Join Date: Oct 2012
belt slip
recently put on the innovator west crank pulley with the 9.1" ring adn rotofab intake. (running 100 octane via torco) and no tune. did a few good pulls going to a local meet the over the weekend and got some belt slip around the 5k rpm range. belt is already tight as f@wk could barely get it on when i swapped everything out. is there a way to get a bit more grip on the belt? new to SC's here so bear with me. coming from the turbo crowd
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
12-04-2012, 04:55 PM | #2 |
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z Join Date: Jul 2012
There is a larger idler pulley that wraps more belt around the supercharger pulley to help with belt slip. look here to see what i am talking about http://jreperformanceparts.com/gm/20...ng-design.html
12-04-2012, 05:02 PM | #3 | |
12-05-2012, 12:50 AM | #4 |
Drives: 2013 zl1 Join Date: Nov 2012
Got to be a belt problem.. there is no way with the right belt it slips. Your mod is veru common and actually should have better wrap than stock
12-05-2012, 05:12 AM | #5 |
Drives: '21 ZLE A10 Join Date: May 2012
I'm stating the obvious, but double check the belt routing as it can be routed more than one way...it is easy to mess up. Make sure you have the correct length belt and the tensioner isn't at the limit. You want it so that you can barely slip the belt on. Take a pic of your belt and pullies so we can see what it looks like.
12-05-2012, 08:29 AM | #6 |
SLOBRA1
Drives: GT500/Cruze/DMax/Cobra Join Date: Feb 2012
All the above^^^^ + try a new belt.
2010 GT500 Best ET=10.10 - Best Trap=143.59mph
2003 Turbo Cobra Best ET=8.27 - Best Trap=166.42mph |
12-05-2012, 09:01 AM | #7 |
Welcome to the crappy world of messing with blowers and getting belts to work.
Make sure you didn't get anything on the belt. Any oil/fluid/grease/etc and you need to replace the belt.
Nick
Corvette Z06 -1200ish rwhp |
12-05-2012, 09:49 AM | #8 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Remove the blower pulley and send it to me, I No risk, and I think you would be surprised.
will machine in our "Gator grip" free, send it back and you report on the results. |
12-05-2012, 10:38 AM | #9 | |
it only slips when its in 4th or 5th when theres more load on it, its fine in lower gears. it is damp and rainy up here this time of year so i could imagine that may be playing a part? ill get a pic of the belt tonight when i get home just in case.
