Old 12-05-2012, 02:04 PM   #1
ParkerB57
COTW 11/12/12
Drives: 1SS RS IBM
A/F ratio going hay wire
Hey everyone,
Reporting my first issue with the car sense the Turbonetics install in July.
This past Saturday while driving back from the ski resort I was costing down the pass and the AFR went to 20+ as normal but as I got back on the gas it stayed at 20. This had never happened before as it normally shoots back down to 14.5-7 instantly. After a half mile as I started getting scared and looking for a pull off, it went back down to the 14s. It happened one more time on the way home.
So yesterday I go and start the car and the AFR is at 20, then after 30 seconds it dropped back down to the 14s. I blurp the throttle it drops into the 13s then shoot into the 20s again for about 30 seconds. I re-uploaded the Turbonetics tune and same thing.
The car runs fine, no missing, coughing, falling on its face. As well as no trouble codes have been thrown.
I know AFR are controlled by the MAP and oxygen sensors as well as the ECM under normal operating conditions, is it possible one is getting ready to fail. It seems weird to me that the O2 sensor on the PLX devices kit would be going out only a few months old.
Any help or suggestions would be great.
Thanks
Ben
ParkerB57 is offline   Reply With Quote
Old 12-05-2012, 02:14 PM   #2
CyberPredator
50 Shades of Prey
Drives: TT/SS
you could try to recalibrate it.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 12-05-2012, 02:29 PM   #3
Warhead
Warhead's Avatar
Drives: 2010 Black 2SS/RS
Exhaust leak may cause this too
Warhead is offline   Reply With Quote
Old 12-05-2012, 02:44 PM   #4
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I had very erratic readings on my WB once, and it turned out to be the connector to the sensor had started to melt. Too close to headers. Worth checking also...
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 12-05-2012, 03:29 PM   #5
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
On my Aeroforce wideband sensor, it takes 30 seconds for the sensor to warm up before giving an accurate reading. Before the sensor warms up it reads 19.8. This is normal and stated in the instructions.
ITGuy11 is offline   Reply With Quote
Old 12-05-2012, 09:55 PM   #6
Slickcas
Drives: 12' 2SS/RS LS3 IBM
wideband sensors seem to have a short life span. Yes some last a long time but most only last a few years. With a Aggressive setup maybe less then a year.
Slickcas is offline   Reply With Quote
Old 12-06-2012, 05:55 PM   #7
Boost6924
Drives: 2SS/RS
It could be that your heat circuit in your sensor starts to go bad. When you coast down and injectors are shut down, sensor gets out of operating temperature. This will make it read high number, since it's not actually reading. They do wear out and old sensors always start to read higher A/F values than they actually are.
Change the sensor and see what happens.
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
