• HT •
Drives: 2013 2SS/RS 1LE Join Date: Nov 2012
Can You Really Turn Off AFM?
Is it true that you can turn off AFM by shifting into M and then paddle shifting to 2nd, 1st, then 2nd?? It supposedly turns it off until its shifted back into drive?
I searched but opinions differ on it. It would be on a 2013 L99.. |
Voice Of The Voiceless
Not sure on a 2013, but before I was tuned, that pattern did not work. AFM is there to haunt you forever...
Until you get tuned
Booooosted.
I don't see how it could really work in shift mode. And if it does, just keep it in a lower gear to cruise at a bit higher rpm. I NEVER drive without shifting anymore. My paddles on the shifter makes it easier and funner.
I was told if you put it in M it was shut off. I just had it tuned out on my 2011 SS.
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
No combination of anything would ever completely make AFM go away on my 2010.
I will get tuned at some point, but that will be a ways away...
#6 |
whats AFM?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
#8 |
What does that do ? i have been using the paddle shifters alot lately a few days ago was my first time using them was very fun lol
#9 |
Doesn't affect your car (V6's). On L99's it shuts down 4 of the cyl's at certain times like cruising on the highway in order to be more efficient. It causes a little bit of lag sometimes that can be annoying as it's switches back and forth.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
#10 |
• HT •
I'm having an interesting convo with a GM rep online about this... I'll copy and paste it when I'm done..
#11 | |
Autoboticus Roboticus
#12 |
• HT •
What do you make of this?!
Here is the conversation: Dave: Can AFM be turned off in an auto, 2013 Camaro 2SS by shifting into paddle shift mode or any other way... Neskens D: If you are in paddle mode or manual shifting the AFM system is automatically deactivated. In automatic the system act independently of the drivers input. Its activated by determining the vehicle needs horse power and torque. When on the highway and cruising the engine will use its cylinders as needed. You cannot activate nor deactivate the system on your own. Dave: But, if I'm in manual mode, it will stay off? Neskens D: The 2 SS uses both Active Fuel Management and sequential fuel injection. When in manual you will be using the sequential fuel injection. Dave: Ok. Sorry but I just want to be clear. Whether I am driving in a neighbourhood or cruising at 100km/h on the highway, as long as I stay in manual mode, the AFM will stay deactivated? Neskens D: Yes your understanding of the system is correct, at low speed or cruising if you are using the manual system, your active fuel management will not engage. Allowing you to use all the power you would like to get out of car. Dave: Thanks so much for clarifying. I purposely asked a few times to make sure I was reading it right... |
#13 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
#14 | |
