Adding 5 channel amp
I wanted to add a 5 channel and remove the factory crap one. I have a 10" sub that I want to add to the mix as well. In order to keep everything working properly, what are my options? Seems like the Fark 3.0 is the simple solution to my problem?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Those are my plans too. I have the Fark kit and the amp mounting board waiting to go in with a 4-5 channel JL audio amp depending on whehter I decide to add a sub or not.
![]() Drives: 2010 Camaro 1SS/RS #21068 Join Date: Apr 2009
For the $$$, you cannot beat the JBL GTO-5EZ amp for $399. 50w x4 RMS @4ohm + 500w x1 RMS @2ohm. Easy to install and setup. Only thing not included is a GTO-RBC for another $40 if you want it (remote bass control knob). We also sell Hertz and Rockford that both offer several 5ch options but a little more money depending on model.
Kenwood Excelon, Rockford Fosgate, JBL, Hertz, Audison, Illusion Audio, Mosconi, Diamond Audio, Hybrid Audio, WetSounds, & more |
Voice Of The Voiceless
If you have the BA system, then yes the FARK harness will make installation go so much easier. Been running my harness and amp for over a year and it sounds great!
![]() Drives: 2010 Camaro SS Join Date: Oct 2010
I've got the FARK system and a 5 channel amp and I'm definitely happy.
I decided to ditch the rear speakers and now just have the fronts wired in and IMO it sounds MUCH better. Point is don't rule out a 4 channel amp you can bridge the rear channels on to power the sub.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
#6 |
Is the FARK kit nessesary? Or is it only used just to not cut wires?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
It's just used so that you don't have to cut up your factory wiring.
