![]() ![]() Drives: 2011 camaro 2ss/rs rally yellow L99 Join Date: Nov 2011
Caring For My Battery
So last year I put my car away and had my battery on the trickle charger all winter[5 months or so]. This time around I was just gonna leave the battery sitting and a week before I get the car on the road I was gonna hook it up and charge it. Are there any cons or pros to that idea or should it always stay on the trickle charger?
- Airaid cold air intake - Kooks 1 7/8 long tube headers
- Kooks high flow cats - Borla atak 2.5" cat back exhaust - Dyno tune - AFM delete - 94 octane tune - Vitesse paddle shifters - Blacked out rims - Costum painted engine cover - T3 stripes - GM locking gas cap |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Battery Tender. If your batt goes flat it'll be shot and you may need a security relearn.
![]() ![]() Drives: '02 Trailblazer, '12 Camaro 2SS/RS Join Date: Jun 2012
why should a relatively new battery go "flat"? My car is stored in a Conex container with no power. I'm hoping as a 2012 with a new healthy battery it'll be fine for 6 months. At worst i'll use a little portable jumper to get it started. Is that an inaccurate perception?
#4 | |
![]() ![]() Drives: 2013 2LT/RS SIM/Grey lnt/Sun/Nav Join Date: Jul 2012
If your lock your doors with your remote, the security system is active and draining. I know that I can query my car with OnStar, and that has to use battery sitting there waiting for a query. Certain computer components are drawing battery to keep their settings intact.
Rally Stripes - Check
Hockey Stripes - Check Gills - Check Ambient Lighting - Saving my $$$ now |
Interesting, what's a life span for a battery and is this something to worry with a 2011?
#6 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
My buddy's trailblazer SS won't start right now out in the garage after sitting for a month. He said the battery is new, I dunno? I let the Camaro sit out there for a few months with no charge and it fires right up. I never used battery tenders on any of my cars.
Usually I get about 5-6 years out of a car battery, if I keep the car that long. I've been getting 8 years out of my motorcycle batteries but they are on tenders most of the time when they sit.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
#7 |
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM Join Date: Jun 2012
Okay, your battery will be fine. One of the features of your car at this time is it has a new battery. As a matter of convention, it comes with the following, from the spec sheet:
Battery, maintenance-free with rundown protection and retained accessory power. So when you get someone stating: "Once a car battery goes dead the components usually sustain some damage. It will never be the same", ............................ You can rest assured, it will be fine. Or when Bugs Bunny states: "With all the constant-on toys in our cars these days, there is a constant drain on our batteries. I wonder if it will even sit idle for six days. If your lock your doors with your remote, the security system is active and draining. I know that I can query my car with OnStar, and that has to use battery sitting there waiting for a query. Certain computer components are drawing battery to keep their settings intact. Bugs is worried about leaving it for 6 days......... You will be fine. |
#8 |
#9 |
![]() Drives: 2013 1ss Join Date: Jul 2012
I have been trying different combos of how to store a battey for years but mostly on cycles. The worst combo I found so far was to use a maintainer/trickle charger but not keep it on the whole time. I moved it to three different batteries all winter and the next spring I bought three new batteries, for a lawn mower motorcycle and 4 wheeler. They were from 1 to 4 years old.
This winter I have 4 chargers hooked up and left on the whole time to see what happens. |
#10 |
![]() ![]() ![]() Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Battery run down protection will not save the battery, it is simply a timer that shuts off any items left on by the driver when they turn off the car.
Leave the lights on and 10 minutes later they turn off, same with the trunk light, dome light, radio and so on. The battery will be damaged and never have the same capacity once it is fully discharged. Parasitic loss from the battery is significant in modern automobiles due to the electronics which are allways powered up. Cold temperatures also reduce the capacity of the battery. Battery tenders are cheap and well worth the money and pay for themselves by providing years of extra service life from your battery.
#11 | |
Drives: car Join Date: May 2008
Another myth battery engineers laugh at? Sitting a car battery on concrete will discharge it. As for battery lifespan depends a lot on environment. Heat really kills them. When I lived in Phoenix they'd usually crap out in about 3 years, here in Indy usually get almost double that. The five + year old battery in my truck just crapped out the other day. http://en.wikipedia.org/wiki/Deep_cycle_battery "A deep-cycle battery is a lead-acid battery designed to be regularly deeply discharged using most of its capacity. In contrast, starter batteries (e.g. most automotive batteries) are designed to deliver short, high-current bursts for cranking the engine, thus frequently discharged of only a very small part of their capacity. While a deep-cycle battery can be used as a starting battery, the lower "cranking amps" imply that an oversized battery may be required. A deep-cycle battery is designed to discharge between 50% and 80% depending on the manufacturer and construction of the battery. Although these batteries can be cycled down to 20% charge, the best lifespan vs cost method is to keep the average cycle at about 50% discharge,[1] as there is a direct correlation between depth of discharge on the battery and the number of charge and discharge cycles it can perform.[2]" To the OP, the most important thing it to either charge it and unhook it, or keep it charged with a trickle charger if hooked up in the car. Just don't let it go dead. Last edited by MLL67RSSS; 12-07-2012 at 08:39 AM. |
#12 | |
![]() ![]() Drives: 2012 AGM 2SS/RS Join Date: Mar 2012
