![]() Drives: 2012 Camaro 2LS yellow/black Join Date: Jul 2012
time between oil changes and first oil change
I'm so used to the 3,000 oil change interval of old cars.
My new Camaro is at 3,500 yet the computer says Oil Remaining 63%. Oil isn't clear nor black/dirty (in middle, brownish). Does this sound right? (just double-checking) Salesman said to change oil after 1 year, no matter what. -- Jim Brooks jbrooks3d gmail |
#2 | |
Then again....there are people on here that will say to drive it till the change oil light comes on.
2018 2SS hot wheels convertible
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Newer cars/Oils can go much further between oil changes safely.
The oil monitor in you car does much more than just keep track of the mileage from the last change. The short answer is yes, you can trust the oil monitor (let the flames begin) for the most part. Change it every 3,000 if it makes you feel better by all means. I usually decide to have mine changed when the oil monitor reads 40% life remaining just to be on the conservitive side. And yes, it's reccomended that you change the oil at least once a year regardless. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS , 1970 Z-28, 2002 Avalanche Join Date: Aug 2009
My first oil change was at 1500 miles, second was at 3500 miles and now I change it every spring when I take her out of winter storage. I only have 9986 miles on her and I bought it in October of 2009.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ Livernois Motorsports 2C Cam kit Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust Roto-Fab CAI / Port Intake Precission 2400/2800 Converter/3.73 AAM gears Livernois Motorsports Tune Best time: 11.97 @ 117 MPH |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Had first oil change at 600 miles. Then every time i need it. Either right before and after a day of racing unless pretty new oil. Then every 3k otherwise.
Regardless of the method you use as i have seen some people who go 7,500 miles between. Always check your oil level weekly. that is not something the OLM will tell you. |
#6 |
Let's go Rangers!
My 1st oil change will be done next Saturday with about 500 miles. After that at 2K, then every 4K miles.
Changing oil regularly is cheap insurance for your engine. |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
I follow the OLM. But as much as it takes into count, it keep track of the time?
Yeah, I'll get around to it...
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I follow the OLM, but never go over 6 months.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
#9 |
![]() ![]() ![]() Drives: 2013 ZL1-Victory Red-Auto Join Date: Mar 2010
My car is like my child to me. I dont care what anyone tells me. Changed at 500, then 1500, then every 3000.
Mobil 1 and a KN oil filter. Yes, most folks think I am wasting money. I dont, and I am the only one who counts.
#10 |
In theory you can change it when the system says to but it doesn't account for oil consumption which all engines do. Some more than others. So while it may not be necessary to change it you should still check the level and add if needed to avoid any issues from a low oil condition.
That said I change mine every 2500 and always use Royal Purple. Regardless of what the monitor says. It's cheap insurance to protect the engine. I've done the same with my truck and it runs the same and as strong as the day I got it.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
different strokes for different folks.
I did 1,500 for first change, was free at dealer.. Now I will follow the OLM, it is there for a reason, I have followed it on all the vehicles I've owned that have had it since 2001 without issue.. Seems to hit the 20% mark around 7K on most cars.. Which is more than acceptable miles on synthetic oil. Once a year or by the OLM is your manufacturer recommended interval as described in your owners manual. Anything else IMO is a waste of money.
I'm only responsible for what I say, not for what you fail to understand.
#12 | |
![]() Drives: 2014 Camaro SS 1LE Join Date: Sep 2012
Haven't heard of many folks using that oil. I did when I had a car. |
#13 |
![]() Drives: 2010 2SS Camaro silver black stripe Join Date: Aug 2011
http://www.camaro5.com/forums/showth...rch+oil+amsoil
I bough used, but I say, break in the car nicely, if not done so. I would say driving nicely for a bit, changing the oil, break in hard, change oil, then drive as you normally do, and change oil after the monitor says, or depending on your oil. Myself I use Amsoil, and I drive 3 miles each way to work monday thru friday, and some days I drive more for fun or other needs, and every so often(every other month or more) I have a 500 mile trip each direction somewhere. I change my oil about every 10000 miles. yes, 10k miles. I trust my oil, and when I change it, still looks somewhat clean. One of my friends(drives a 2010 mustang gt) use mobil 1 and we changed oil the same day, he after 4k miles, and me just after 8k miles(I was doing a 800 miles trip each direction and wanted a cleaner oil just because I had some money at the time. My oil looked cleaner than his.
AIRAID cold air intake, Borla headers long tubes stainless steel, MBPR Performance Cat back X-pipes,custom cam from Virginia Speed, CNC Ported Heads from TEA, Heritage grill
#14 | |
