Old 12-06-2012, 08:09 PM   #1
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
Drive Shaft Bolt Torque Procedure on SS?
Does anyone know the torque setting for the 3 Bolts securing the Driveshaft to rear differential input shaft? I'm talking about the bolts that thread into the diff input shaft, not the ones secured with nuts. if it makes a difference, it's an LS3.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 12-06-2012, 08:21 PM   #2
Spektrum
Spektrum's Avatar
Drives: 2013 2SS 1LE
Propeller shaft to rear differential flange bolt = 85 lb ft
Hope that's what you're looking for
Spektrum is offline   Reply With Quote
Old 12-06-2012, 11:07 PM   #3
Ron66Vette&10SS
Yup, that's what I'm looking for
Does the manual call for loc-tite?
Old 12-07-2012, 11:29 AM   #4
Spektrum
Spektrum's Avatar
I referenced AllData for this information and it didn't not specify, but to answer your question: Most likely yes, you need to use loc-tite.
If the flange on the driveshaft is a different metal (aluminum mating against steel, for example) than the pinion flange then you need to, due to the metals expanding at different temperatures. You could probably inspect the old bolts and see that it was previously used on the threads.
Sorry it took so long to get back to you. Good luck!
Old 12-07-2012, 11:36 AM   #5
Russell James
Russell James's Avatar
You should be using new bolts which come coated. If your using something without coating, then yes on the loctite. More loctite will never hurt if there is a question.
Old 12-07-2012, 12:24 PM   #6
Ron66Vette&10SS
Cool.....thanks guys
I've got 3 bolts coming which should be here next week. I'll see if they already have a stripe of threadlock on it when they come in.
Last year I had a bolt break and the other 2 bend. They ended up replacing the differential input shaft, coupler, diff seal and bolts. After waiting a week for parts, it still took them a couple of days to get the work done. Then a couple weeks later it started vibrating again.....got underneath it and saw that the bolts were backing out. Took it back to the dealer, the mechanic claimed he torqued it correctly (yeah, right!) and they replaced (supposedly) the bolts again.....anothr couple of days down. When I picked it up the second time, the service manager asked me if I realized how much more the rear tires were worn than the fronts, smiled and said: "You need to stop taking it to the track, brother" (which I never have, by the way).
It'll be a lot easier, quicker and convenient to just replace them myself this time. That way I can be SURE that it's done right, AND I don't have to worry about somebody possibly getting a wild hair and trying to void my powertrain warranty due to allegations of abuse.
Old 02-29-2016, 03:16 PM   #7
Big Brunsy
Drives: 2010 supercharged LS3
How about the other bolts that hold the rubber to the shaft? Same spec?
Big Brunsy is offline   Reply With Quote
Old 02-29-2016, 04:06 PM   #8
Big Brunsy
Anyone else who looks for this info in the future can now find it all here.
Drive shaft to coupler bolts - 67 ft lbs
Coupler to trans flange - 72 ft lbs
Coupler to diff flange - 85 ft lbs
Old 03-01-2016, 08:45 AM   #9
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Get an inexpensive beam type torque wrench and replace them according to the book. Never reuse the fasteners as they are torque-to-yield and are only good once. Never let the dealership touch the driveshaft bolts. They should not be "re-tightened" in service. If they are loose, the have failed.
Old 07-27-2016, 09:34 AM   #10
sickspeedSS
Drives: 2010 Camaro SS M6
67 ft/lbs is for the torx headed bolts with the lock nuts correct??
sickspeedSS is offline   Reply With Quote
Old 07-28-2016, 09:50 AM   #11
sickspeedSS
can you confirm that the 67 ft/lbs is for the torx bolts?? ive called 3 dealers and they act like its an act of congress to find the torque values for a 2010.
Old 07-28-2016, 01:33 PM   #12
Merc
In The Circle
Merc's Avatar
Stock driveshaft is the weakest link in the drivetrain, especially in the M6. Bolts can loosen and bend and there a throw at that point.
Old 07-28-2016, 04:49 PM   #13
sickspeedSS
What kind of replacements are available that will mate with the transmission and stock differential???
Old 07-29-2016, 03:17 PM   #14
Merc
In The Circle
Merc's Avatar
DSS makes a 1 piece aluminum shaft.
