Old 12-08-2012, 07:35 PM   #1
Sean Summers
Sean Summers's Avatar
Drives: 2013 ZL1
Overheating
It is still in the mid 70s here in NW Florida. My ZL1 runs between 190-210 normally but if I am in traffic with the AC on it can spike up real quick and has even shut the AC down due to high heat. I am just over 1000 miles and this does not seem right. Summer time down here with tourist traffic and 100 degree heat I will be cooking the car. Any ideas??
Sean Summers is offline   Reply With Quote
Old 12-08-2012, 07:49 PM   #2
mcotton
mcotton's Avatar
Drives: 2010 Camaro
Take it to the dealer, your air should not shut off and if it is I would take it in to be ooked at. My 2012 2SS/RS heats up during bumper to bumper traffic but my fan kicks in and cools it off. Maybe your thermostat is bad?
mcotton is offline   Reply With Quote
Old 12-08-2012, 07:49 PM   #3
Taser Deployed
Taser Deployed's Avatar
Drives: 2012 Blk ZL1
Take it to the dealer. Mine did the same thing and the tech said it was a software issue with the AC unit.
Taser Deployed is offline   Reply With Quote
Old 12-09-2012, 07:34 AM   #4
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
How hot did it get. I drove to PA this summer and it was 100+ and I was never over 210.
Happy_Dan is offline   Reply With Quote
Old 12-09-2012, 07:46 AM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Check that you haven't sucked a Walmart plastic bag up in front of the radiator or stuck between the radiator and condenser core. I assume the obvious that you already checked your coolant level.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 12-09-2012, 12:10 PM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Coolant level can cause this condition because the thermostat does not function correctly.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
Old 12-09-2012, 01:07 PM   #7
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
There was a Recall for the ac to be reprogrammed on my SS, I wonder if your car is subject to this recall to. It was only applicable to some cars and not others in the same model year.
One-Bad-ZL1 is offline   Reply With Quote
Old 12-09-2012, 01:18 PM   #8
Scarrzz
No Fear-No Limits- Camaro
Scarrzz's Avatar
Drives: '13 ZL1 or Suzuki Hayabusa
I had a problem in another vehicle that caused the fan to not kick on when sitting stopped at idle. That would also explain this issue.
__________________________________
................................................The Faithful are Watching.
Scarrzz is offline   Reply With Quote
Old 12-19-2012, 07:48 PM   #9
Sean Summers
Drives: 2013 ZL1
The wiring harness to the cooling fans was disconnected. The dealership says that the fan does not kick on until the coolant temp hits 230 anyhow. 230 seems like an awefully high high number to hit before starting to try to cool down this engine. Even if that will not hurt it, wouldn't running that hot rob you of a mess of horse power?
Old 12-19-2012, 07:55 PM   #10
OldScoolCamaro
There is a problem in high temp regions of the Country where the A/C cuts out. This issue has been posted many times. There is resolve to correct the problem. A software, or update can be performed on the car by the dealership that will correct this issue. It has been documented here on C5. That may have some connection to your problem, or you have a low coolant level or another issue associated with the cooling system. There's been an issue with the A/C in extremely hot areas of the Country, but not the cooling system in general.
