12-08-2012, 08:22 PM | #1 |
Drives: 2013 2ss se/ 2009 cobalt ss Join Date: Nov 2012
Forced Induction and wheel hop
All,
How many of you after installing a super charger had wheel hop issues. I am trying to decide if I need to address this now before the super charger is installed in a few weeks. I would rather spend money elsewhere right now but I also do not want to damage anything. |
12-08-2012, 08:35 PM | #2 |
Burning up tires
Drives: 2023 ZL1 Vert Join Date: Jul 2010
Suspension first, then add power.
12-08-2012, 10:15 PM | #3 |
Drives: Twin turbo G8 GXP Join Date: Dec 2012
Is your car automatic or manual?
12-08-2012, 10:19 PM | #4 |
chevy pride
trailing arms will do alot for u.after that u can do a lil here and there.
check out ky speeds fb page https://www.facebook.com/kyspeed |
12-08-2012, 10:34 PM | #5 |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
I think sub frame bushings are a better place to start than the trailing arms.
There is certainly no crime in doing suspension first, but if you are not having a wheel hop problem, why try to solve it? Again, I would go with a sub frame bushing first. Starting with a trailing arm might solve the problem (or future problem in this case) but it isn't the weakest link in the equation. |
12-09-2012, 12:07 AM | #6 |
12-09-2012, 12:34 AM | #7 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
It will need lots of suspension work then. L99 can get away with little to no suspension work to get the power down but the M6 needs the book thrown at it. Trailing arms, diff bushings, and cradle bushings at the minimum. Do fuel pump and maybe gears at the same time as diff and cradle bushings to save your self some labor.
12-09-2012, 12:51 AM | #8 |
I was afraid you were going to say that.
12-09-2012, 05:50 AM | #9 |
Drives: 2011 2SS/RS Join Date: Aug 2012
I have an L99 and I'm S/C. All I did was sub frame bushing kit, trailing arms, toe rods and the wheel hop was gone. Next up is some GFORCE axels and my suspension will be good to go for awhile. The manuals need all this plus a little bit more.
12-09-2012, 06:58 AM | #10 |
Drives: 2011 Blue1SSRS 623RWHP, 02 vette Join Date: Aug 2010
600+ rwhp with a m6 and no wheel hop!
23k on the car and rear dif bushings are needed but she will spin at will with no wheel hop! I always do my burn outs from a roll 10-20 mph dump second and she is good for over 300 feet + then third till you run out of road !
2002 Vette (stock)
Team LS-3 |
12-09-2012, 06:59 AM | #11 |
Slicks at the drag strip did just fine as long as I left under 3 k
2002 Vette (stock)
Team LS-3 |
12-09-2012, 08:30 AM | #12 |
BLOWNSS
Drives: 2011 SUPERCHARGED Camero SS Join Date: Dec 2010
Trailing arms and bushings pretty much solved my hop
2011 LS3 SS/RS, M6, Maggie TVS2300 - cog drive, CAI, ZL1 fuel pump, Autometer gages, BEHE Performance tune , boost and AFR gages, MGW shifter, SLP long tube headers with high flow cats, Flowmaster Pro ex., Pfadt trailing arms, toe rods & bushings, G-Force axles, American Racing wheels, 305 mm P zero on rear, Elite catch can, SLP hood, amp & sub.
12-09-2012, 09:18 AM | #13 |
Differential bushings, trailing arms and toe rods here. Still had a little hop but not like when it was stock. Drag radials made the biggest difference with my car
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
12-09-2012, 09:22 AM | #14 |
I just bought everything I could get basically except the under body bracing. Do you guys only experience the wheel hop with the TC off? I keep it on and usually never get hop, if I take it off then its more present.
