Old 12-12-2012, 10:06 AM   #1
SGNL99
Drives: 2010 2SS/RS CGM
Differential Main Caps
I am looking at doing a swap to the 3.91 1le gears. My question is about upgrading the main caps to the billet ones. Is it worth the extra $200 for a DD? I'm putting down 415 now with the JRE package and my ultimate goal for the car is to go to 470 with Ted's rough idle blower cam. Are the stock main caps good for ~500 hp or are the billet caps worth the extra insurance? Thanks.
CAI Black Intake w/ Apex scoop & ww bottle kit; VMAX throttle body; Borla S-type Cat back exhaust; Skip shift eliminator; Elite Engineering catch can; MGW short throw shifter; Stainless Works LT Headers w/ Hi-Flow cats and one awesome JRE TUNE! BMR stage 2 suspension; 3.91 gears
SGNL99 is offline   Reply With Quote
Old 12-12-2012, 10:29 AM   #2
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Better to have them and not need them.....
Rather than wishing you would have installed them while looking at your newly "shredded" gears!!!!
Cheap Insurance in my opinion!!!
These are the JRE caps going in along with my 3.91's & Truetrac.
blazzin1 is offline   Reply With Quote
Old 12-12-2012, 02:39 PM   #3
BlackPearl
Drives: 2010 ss
after you see them next to each other you would never reinstal the stock caps. i went with billet caps on my 1le diff
BlackPearl is offline   Reply With Quote
Old 12-12-2012, 05:06 PM   #4
blazzin1
blazzin1's Avatar
These are the "stockers". Kinda hard to compare when they are not in the same picture, but the JRE caps are significantly thicker in all areas. You can also tell a big difference in the quality compared to the "cast" aluminum stock pieces.
Old 12-12-2012, 05:49 PM   #5
SGNL99
Thanks for the replies. I'm guessing the aftermarket diff support plate is another "must"?
Old 12-12-2012, 06:11 PM   #6
SC2150
Make sure you machine the caps for proper fit when installing! Excellent mod.
Old 12-12-2012, 06:19 PM   #7
blazzin1
blazzin1's Avatar
What is a diff support plate? Do you mean the diff cover? If so, it's really not needed in addition to the billet main caps.
Old 12-12-2012, 06:55 PM   #8
SGNL99
My bad, yes the support cover. So the billet main caps will suffice with the stock cover?
Old 12-12-2012, 07:19 PM   #9
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
So what is the added strength with caps, gears, axles, compared to a 9", or a ZL1? What is trashed when the rear blows?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-12-2012, 10:31 PM   #10
blazzin1
blazzin1's Avatar
Yes, my machinist said he had to take approximately .060" off the new main caps to meet the 3.062" bore requirements.
Yes, from what I've been told, the LPW Differential Cover with the pre-load bolts is not necessary with the billet caps. However, with that being said, I'm still doing both! It may be overkill, but I figure a little more added insurance isn't going to hurt anything.
The billet caps reduce the amount of torsional flex or movement within the aluminum rear end housing. Regardless, you will still not have the strength and/or rigidity of a 9" or cast iron ZL1 rear end. But then again, you're not spending $5-$6k on a rear end, and you're keeping the added weight off too. Without wheel hop, you're probably safe with a modded OEM rear end up to about 500-550-ish HP. After that, most rear end failures result in broken spider gears within the posi-unit or probably more so broken teeth on the ring and pinion. Coincidently, most of R&P failures that I've seen on here have been with the early Richmond gears, but much of that could be attributed to faulty gear installations.
Old 12-12-2012, 11:21 PM   #11
Chris82xx
Chris82xx's Avatar
So for someone like myself, it would be more cost efficient to just buy a new rear end. With the upcoming upgrades, I'll be put close to if not over 800rwhp, but this is going to be a street car, I probably won't launch it too often.
811RWHP/719RWTQ
Old 12-12-2012, 11:24 PM   #12
Supercharged SS
Drives: 2010 Camaro
Chris, is your car an A6 or M6?
Old 12-12-2012, 11:29 PM   #13
Chris82xx
Chris82xx's Avatar
M6
811RWHP/719RWTQ
Old 12-12-2012, 11:30 PM   #14
Chris82xx
Chris82xx's Avatar
As naive as this sounds, I do all this to the car just to do it as a hobby and show off. You don't see many convertibles like this so I figured, what the hell.
811RWHP/719RWTQ
