![]() Drives: 2013 Camaro 1LT RS Join Date: Jun 2012
V6 SPRING RATE
Could anyone tell me what the stock spring rate for a 2013 1LT V6 is? I have searched but cant find anything but V8 which I think is 150frt and 375 rear. Thanks
Loyalty above all else except honor!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Don't know if this helps- Super Chevy 2010 Camaro suspension specs. Don't if there were any changes to the 2013 V6. 2012 V8 got the FE4 susp.
Two suspension packages are offered: FE2 sport on V-6 models and FE3 performance with the V-8. The front suspension has a dual ball strut system, with a direct-acting stabilizer bar that measures 22.2 x 4 mm on FE2 and 23 x 4.2 mm on FE3. Hollow bars are used for mass savings. The front spring rates for FE2 models are 25 Nm, with wheel travel at 96 mm. FE3 models include a stiffer, 27 Nm spring rate, with wheel travel reduced at 84 mm. ![]() Rear suspension features include high lateral stiffness for handling via three lateral ball joints per side. A sub-frame at the rear is double-isolated to minimize vehicle body motions and dampen road imperfections. The FE2 with a manual transmission includes a spring rate of 53 Nm, with wheel travel at 115 mm, and employs a limited-slip differential. The FE3 rear axle uses a limited slip differential on both manual- and automatic-equipped models; and the rear spring rate is increased to 66 Nm and wheel travel is reduced to 100 mm. Coil-over shock absorbers are used in the rear with a decoupled, hollow stabilizer bar. FE2 includes a 21.7 x 3 mm rear bar, while the FE3's large bar measures 23 x 3 mm. Read more: http://www.superchevy.com/features/c...#ixzz2EzJxfF6H |
Drives: faster than dirt... Join Date: Jun 2012
What are you looking to do?
#4 | |
Drives: Camaro Justice Join Date: Jun 2007
Front FE2 25 Nm, FE3 27 Nm Rear FE2 53 Nm FE366 Nm 220 / 240 front and 370 / 470 rear in round numbers. What are you planning? |
