Old 12-15-2012, 11:54 AM   #1
prkfreds
Drives: 2011 Camaro 2SS
Headers
What are the best long pipe street headers for the L99?
prkfreds is offline   Reply With Quote
Old 12-15-2012, 11:59 AM   #2
rjdapilmoto
DAP-ONE [COTW - 12/23/13]
rjdapilmoto's Avatar
Drives: 2010 - 2SS/RS IOM
American Racing....FTW!
rjdapilmoto is offline   Reply With Quote
Old 12-15-2012, 12:10 PM   #3
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
Check this out.
http://www.camaro5.com/forums/showthread.php?t=246331
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 12-15-2012, 01:24 PM   #4
SLEEPER SS
Banned
Drives: 2010 2SS/RS
Kooks long tubes is what I have. Best money spent
SLEEPER SS is offline   Reply With Quote
Old 12-15-2012, 03:31 PM   #5
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
The best long-tube headers for YOUR Camaro will be the ones you install. They all do about the same. The tune is way more important than the headers. I know owners with Kooks, ARH, Texas Speed, as well as several others. They all do the same job if tuned properly.
stso634 is offline   Reply With Quote
Old 12-15-2012, 04:41 PM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The good news here is that this is hard to get wrong. Ask around on the forums and you will hear some of the same brand names over and over again. If you stick to the well known brands like Stainless Works, ARH, Kooks, or Stainless Power you will be good to go. From a performance stand point all of them are pretty close, no one has a secret that makes one brand produce substantially better results than any of the others. It’s mostly a question of quality and again most of them are pretty close in this area as well, but there are a couple of things to pay close attention to as you look at brands other than those listed above.
Pay attention to what they are made of. Stainless steel (particularly 304L) is what you will want to look for. 304 stainless steel will not rust or discolor from exposure to the atmosphere like the cheaper 400 series stainless steel. Unlike aluminized steel, it will not rust from the inside out due to the corrosive fluids produced during combustion. 304 can discolor slightly from getting extremely hot or if you spill engine oil on them but another attribute is that it isn’t permanent.
Pay attention to how they are made. CNC mandrel bending is the best manufacturing method for producing exhaust systems and headers that flow and fit well. When this process is used in conjunction with the 304 stainless steel it allows for the use of a thinner wall tubing that will weigh less than other headers. Those weight savings will be lost, however, if you opt for the ceramic coating some manufacturer promote. With stainless steel the coating isn’t needed for corrosion resistance purposes (ceramic coating is often pushed because the manufacture is using inferior material) but it will reduce under hood temps. Plus is looks nice.
Primary diameter is the area that seems to cause the most confusion but it is fairly straight forward. Header manufacturers usually offer two or three options when is comes to primary diameters for a specific vehicle. For example, for the new 5th generation Camaro SS most manufacturers are offering 1 3/4 inch, 1 7/8 inch, and 2 inch primaries. Here are the results of some recent back-to-back testing on an otherwise stock SS:
Stock: 372 RWHP 376 RWTQ
1 3/4 headers with high flow cats: 401 RWHP 404 RWTQ
1 7/8 headers with high flow cats: 408 RWHP 409 RWTQ
2 headers with high flow cats: 413 RWHP 410 RWTQ
As you can see, simply switching from the restrictive stock manifolds to 1 3/4 long tube headers is worth approximately 30 RWHP and 30 RWTQ on a bone stock Camaro SS. The larger the primary diameter gets the more air the headers will flow and the further up the RPM range the power band is moved. The impact of the larger primary diameters is magnified the more powerful the engine is, especially when you introduce forced induction. This means that generally the more power you make or the more race oriented your application is the bigger primary diameter you need, the closer to stock or the more street oriented the smaller primary diameter you need.
In the specific example of the 2010+ Camaro SS, we have found that the 1 7/8 long tube headers are the best all around header for the typical bolt on modified car that is driven regularly and occasionally taken to the track. They offer a tremendous improvement over stock with room to grow as owners modify their car further. The 2 inch headers offer very similar numbers to the 1 7/8 headers up to 5000 RPM where the 2 inch headers pull ahead. They are ideal for those running forced induction or for race applications.
If you have any other questions feel free to hit me up.
Old 12-15-2012, 05:13 PM   #7
bluetooth-ss
Got stainless works and high flow cats on mine.I'm pretty happy so far.
Old 12-15-2012, 06:12 PM   #8
Apex Motorsports
Can't go wrong with Stainless Works.
Old 12-17-2012, 05:49 PM   #9
LSR SAL
LSR SAL's Avatar
Drives: faster than dirt...
kooks makes a great product. Very high quality and american made! Let me know if you need a quote. i can set you up with a sweet package deal
LSR SAL is offline   Reply With Quote
Old 12-17-2012, 05:52 PM   #10
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
any of the top brand are perfect.
Joe@CPR.com is offline   Reply With Quote
Old 12-17-2012, 05:58 PM   #11
Midway Chevrolet Performance Center
Midway Chevrolet Performance Center's Avatar
Drives: 2010 & 2012The Camaro SS
Dynatech's, Kook's or ARH are the 3 best out there. Pm me if you need pricing.
Midway Chevrolet Performance Center is offline   Reply With Quote
Old 12-17-2012, 06:52 PM   #12
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
Decisions decisions!!!
white1LE is offline   Reply With Quote
Old 12-17-2012, 07:02 PM   #13
2010 4 DW
Drives: White 2010 RS/SS
I have the JBA 1 7/8" Stainless & Ceramic coated Long Tubes and they are VERY nice. They had V-band clamp connections and included o2 extensions so they are a great choice.
http://www.camaroperformers.com/cama...car/index.html
2010 4 DW is offline   Reply With Quote
Old 12-18-2012, 12:15 AM   #14
Double D Mods
Double D Mods's Avatar
Drives: 2012 Grand Sport Convertible Vette
good thing you have me to get you a good deal on headers
Double D Mods is offline   Reply With Quote
