Old 12-16-2012, 12:51 PM   #1
AirManFL
Mid-Florida Camaro Club
AirManFL's Avatar
Drives: 2018 ZL1
Bleeding Brake Question
I'm getting ready to change my calipers and I'm wondering if there is any reason I can't change and bleed them one at a time?
Thanks,
Rob
AirManFL is offline   Reply With Quote
Old 12-16-2012, 03:00 PM   #2
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
When I change calipers I normally do a fill/bled on the bench prior to installing them on the car. This will take alot of the air out of the caliper and make bleding the brakes easier when everything is over with.
I dont see why you would want to change one, bleed one, change one, bleed one........ Seems like it would be easier to change them all then bled the entire system at once.
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 12-16-2012, 06:09 PM   #3
AirManFL
AirManFL's Avatar
Drives: 2018 ZL1
Thanks for the reply. We were almost done and only did one at a time. 3 of my jack stands grew legs and walked away and I didn't want to bleed them with the wheels on.
It worked out...
Rob
Old 12-16-2012, 06:09 PM   #4
JusticePete
Drives: Camaro Justice
Nice.
Old 12-16-2012, 07:31 PM   #5
SanteeChev
Drives: 45th Anniversary Edition
Isn't there a program in the ecm that automates the bleeding?
SanteeChev is offline   Reply With Quote
Old 12-16-2012, 09:28 PM   #6
JusticePete
Not that I am aware of. We have used the 2012 Corvette bleed in a GM Tech II.
