Old 12-17-2012, 03:54 PM   #1
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
30,000 mile maintenance
So I start setting up to do my oil change today and decided to give the dealership a call and ask if there's anything special to do at 30k.
Evidently, there is. It'll run me close to $400 and it includes flushing the rear differential, taking fuel system apart and cleaning it, clean/lube/inspect calipers, rotate tires and finally air filter change.
Is this worth it? I'm thinking maybe it is, at least for the paper trail... but I wasn't counting on dropping $400 on the car right now - at least not until I buy tires.
terry_b is offline   Reply With Quote
Old 12-17-2012, 06:26 PM   #2
james347
Drives: 2006 Crownline
Flushing the rear diff? I would just change it myself.
Taking apart the fuel system and cleaning injectors? At 30,000 miles? I really question this one.
Rotate Tires? I thought the back tires were larger then the front?
Mine are, you can't rotate them.
Maybe I am wrong here.
james347 is offline   Reply With Quote
Old 12-18-2012, 01:02 PM   #3
terry_b
terry_b's Avatar
see that's why I ask... I'm hoping more people will chime in. The key elements are the brakes, diff and fuel system - I could do it all, but it would be a hassle. Might be nice to have the paperwork as well...
Old 12-18-2012, 01:16 PM   #4
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I just have the dealership do the stuff that is needed. Somethings I've asked about, they've said not yet. I know having them do the maintence is a bit more costly but it is insurance to me. They cut me price breaks and have done warranty repairs like replacing the valley cover and a valve spring without questioning the headers and other things they could see.
I'm at 46k miles, have had the oil changed every 5k, the transmission, differential, cluth/brake fluid, all changed and the radiator flushed all at my request. They saw my catch can and said, I don't guess you need a top engine clean. Nothing else has been recommened.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 12-18-2012, 01:24 PM   #5
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
BTW you can rotate the back tires but they aren't as suggest as rotating all four of the same size.
I agree with changing the reard diff fluid. Super easy.
Sounds like a lot of money for something that can be done mostly by yourself.
Indy Bumble Bee is offline   Reply With Quote
Old 12-18-2012, 05:15 PM   #6
terry_b
terry_b's Avatar
Rotating the tires is a non-issue. I'm replacing the tires soon.
My real question is are these service items really necessary?
I am no stranger to doing the work myself, I just want to know mostly is it needed at this point. Having the dealer do it comes down to convenience.
If I don't have the dealer do this, could it be a warranty issue down the road? I'm still covered a good while.
Speaking of warranty they're actually fixing an oil leak on the front engine cover near the alternator. They're waiting for parts to do it...
Old 12-18-2012, 06:51 PM   #7
mulletman
Drives: 2017 Camaro SS
You have a K and N filter. Clean and re-oil at 50,000 miles. The recharger kit costs twelve bucks. Cleaning the fuel injection is worthless. Changing the differential fluid is a good idea. Save the money and do it yourself. Checking the calipers is also worthless. Check the brake pads yourself.
mulletman is offline   Reply With Quote
Old 12-18-2012, 09:34 PM   #8
terry_b
terry_b's Avatar
Thanks for your guys' input so far... Really helps to know what everybody thinks
Old 12-19-2012, 10:30 AM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
Please let us know how your service goes once it gets repaired. We are here if you have any questions!
Brandon
Chevrolet Customer Service
Old 12-19-2012, 12:02 PM   #10
matt55
matt55's Avatar
Drives: CTS-V
$400 oil change and rear diff fill , sounds legit :-\
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 12-19-2012, 07:24 PM   #11
GlennP
Drives: 2011 Camaro 2SS
Diff oil change is easier and cheaper than even an engine oil change. Unscrew 2 plugs, wait for it to drain, put bottom plug in, insert one bottle of oil, insert plug and done. That's $20 oil and 20 minutes time if the car isn't already in the air. Caliper check is a joke, lube is to prevent squeaking but if your brakes squeak they will cover under warranty anyways. If they don't squeak no harm done and leave em. Fuel system cleaning? That's a joke too. If you have the same wheels as SS you can't do a true rotation anyways, only side to side but that's a waste too. Oil filter clean is a great idea but requires nothing more than a little time a cleaning kit and probably just a flat headed screw driver.
If you really want all that done, take it to me I'll do it for $150 :P
GlennP is offline   Reply With Quote
Old 12-21-2012, 12:38 AM   #12
rivenwolf
Drives: 2010 2SS RS M6 CGM
Oil change in the rear diff is a must. If you don't have a catch can I highly recommend doing a top engine clean (fuel system clean from some dealers). These engines pick up a lot of oil from pcv making the throttle plate, intake, valves etc. very dirty. Don't due the brake thing. The tech should check you pads for you for free as up sales give good commission. After you get new tires you should rotate your tires if you do NOT have a RS. RS package comes with 8" front and 9" rear wheels and do not get rotated. that being said, 400 is not bad if you want to have a dealer tech do the job.
Just another camaro fan that happens to be a advanced master ASE tech with 100% gm training on Buick GMC.
rivenwolf is offline   Reply With Quote
Old 12-21-2012, 08:02 AM   #13
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Once they saw he had a catch-can, they knew they had an easy mark.
tonyko1 is offline   Reply With Quote
Old 12-21-2012, 10:18 AM   #14
TooCool5
TooCool5's Avatar
This,
Bottle of Fuel injector cleaner in the tank every 6 mo. and your good to go.
Changing the differential is super easy. Just remove the plugs.
Sounds like a dealer money maker. Mine wanted to change all fluids at
30k. when I told them they are synthetics they shut right up.
If it ain't broke, don't fix it.
dealership, maintenance, mileage, service
