![]() Drives: Red 95 Z28 Join Date: Apr 2011
So Just recently it was a year ago when I got my trans rebuild, now rather shortly after I got the job done i started to notice things I wasn't to sure were good, but the shop assured me it was ok. Things like hard shifting and such. But now as of a couple months ago I get this nasty slip or flare up its when I'm driving from about 50 to 70 ish if I give it half throttle or more the rpms go up a drastic 1000-2000 it seems though that I'm still kind of moving, and it will stay this way until I let off the throttle and it makes a banging thump noise to "engage" then it's ok. I have taken it to shop while in warranty numbers of times and it didn't replicate while there. What are your guys recommendation it's extremely frustrating.
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
Almost sounds like the converter is coming unlocked. Mine does that occasionally now with the big stall, hence my need for a better tune, but I don't get a thump when it locks back up.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension 2004 GSXR 1k, Matt Mladin Edition Last edited by xXSilencerXx; 03-11-2013 at 06:45 PM. |
I have a 2200 stall, with no tune that I know of except for some moderate tunes I did with the hypertech I have. But it didnt happen right after the rebuild It's been the last 3-4 months.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: In Circles Join Date: Mar 2011
sounds like a converter problem to me.
why do you think it would be the converter vs something internal of the trans?
#6 |
![]() Drives: 98 camaro 3.8 v6 Join Date: Sep 2012
4l60e had many problems normally overdrive goes out theres a connector on the passenger side of tranny that controls overdrive but i will say that those transmissions are garbage ive had 8 and everyone went out on different vehicles if i were you id look into a different setup
#7 |
What kind of set up would be good to looking into for mostly street driving. I've looked into a little before but what would you recommend?
#8 |
i would highly reccomend an ls1 and find a different transmission than a 4l60e that is able to be converted cause an ls1 is a good power when you need it and safe when you do as well thats my recomendation
| Tags |
| drivetrain, lt1, transmission |
