Old 12-18-2012, 02:19 PM   #1
diamondmike
diamondmike's Avatar
Drives: 2SS/RS
how can i stop the drone
i have just changed the set up and at 1600 to 1800 bad drone what can be done?
2 in ARH
3in pipes
flowmaster 50's
no cats
7.83 @ 172 and 1.15 60ft 5th gen
4.93@143
diamondmike is offline   Reply With Quote
Old 12-18-2012, 02:27 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
Besides swapping to a drone free catback like Corsa or Solo performance you have a few options.
You can try a resonated mid-muffler to replace your X-pipe on the ARH. They come with an internal X style cross over. The results on this vary, generally you'll reduce a good deal of drone but you'll lose some volume with it.
Some people will dyno-mat their trunk and undercarriage. This cuts volume out of the interior real well and even though you'll still hear some drone it'll be a lot quieter.
Look into ordering a set of J-pipes. It's what Solo Performance uses on their catbacks to stay drone free. They would weld onto your existing system and should eliminate all drone while not interfering with the flow.
Juiced1 is offline   Reply With Quote
Old 12-18-2012, 02:30 PM   #3
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Had the same issue. Do a search, there was something about a J pipe. I turned AFM with a new tune.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 12-18-2012, 02:35 PM   #4
CamaroRBT
Who's Laughing Now?
CamaroRBT's Avatar
Drives: 2011 Camaro 1SS RS LS3 Summit White
J pipes
CamaroRBT is offline   Reply With Quote
Old 12-18-2012, 02:36 PM   #5
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Put your stock setup back on...
Old 12-18-2012, 02:38 PM   #6
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Put on the ARH axle back..
I run the ARH 2" LTs, 3.5" Collectors, ARH Axle back.. No drone
Matt @ FSP is offline   Reply With Quote
Old 12-18-2012, 03:53 PM   #7
diamondmike
Drives: 2SS/RS
Thanks guys,
i love the sound now but 48 to 58 mph it's the drone from hell.lol
at 45 mph it quiet as a church mouse. was gonna try a few things see if i can make it better
4.93@143
Old 12-18-2012, 03:59 PM   #8
diamondmike
Drives: 2SS/RS
heres what i found online:
Exhaust drone is primarily the result of sound waves traveling through the air and vibration that is transferred through a vehicle's frame, body and components. Exhaust drone vibration may also be a result of sound frequency alignment between the engine and exhaust. When the frequencies are aligned, the result is a pressure wave between the engine and exhaust. Sound waves, transferred sound and sound frequency must be controlled to quiet the exhaust. Exhaust system modifications and the application of sound control material will reduce exhaust drone in your vehicle
Read more: How to Fix An Exhaust Drone | eHow.com http://www.ehow.com/how_8080950_fix-...#ixzz2FRIh7eH2
4.93@143
Old 12-18-2012, 04:04 PM   #9
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
put in 4.11 gears...that will raise up your rpms by 200-300, which should keep you over 1800 rpms most of the time...and the car will be faster too.
POWERFREAK is offline   Reply With Quote
Old 12-18-2012, 07:32 PM   #10
SPCBA
Drives: pleather and Chiclets
J pipes
SPCBA is offline   Reply With Quote
Old 12-18-2012, 07:37 PM   #11
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Dynamat didn't do crap for me. I ended up removing it, which was a real pita... I ended up going with the ZL1 Corsa system.. No drone. I can finally use my phone while driving. Even the onstar lady sounds better. Lol
kevin1106 is offline   Reply With Quote
Old 12-18-2012, 07:43 PM   #12
2012REDSS
Drives: 2012 Camaro SS
I'm no scientist but the j pipes worked great when I had stock pipes with a resi delete and pype bombs but when I put them on my JBA 3" they didn't help at all. I don't know if pipe diameter changes things. I'm sure Solo can chime in if I'm way off in left field.
2012REDSS is offline   Reply With Quote
Old 12-18-2012, 07:46 PM   #13
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I did insulation, helped a wee bit around town, not at speed.Did resonated x pipe, didnt help much either. J pipes only thing that worked with outlaw axelback and I dont have headers!
VR Baron is offline   Reply With Quote
Old 12-18-2012, 07:51 PM   #14
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
camaro ss, drone
