Old 12-19-2012, 03:28 PM   #1
2010SSRSM6
2010SSRSM6's Avatar
Anyone else have issues with IW's 8 rib OD Crank Pulley?
So, a buddy installed the IW 10% OD crank pulley on his 2010 LS3 powered SS. Since it has been installed it has shredded 3 A/C belts, been sent back to IW only to be told it is within spec's, and just threw the A/C belt off taking the A/C clutch plug and wires with it. The alignment checks out ok with the laser, it's locked down correctly and this belt issue will not go away.
IW wants him to pull it off again, send it back so they can check it again, etc. Needless to say, he is not a happy camper.
I doubt that this is a unique issue and wanted to see what others have done, other than switch out to the LPE part.
He is only using the OD crank pulley and does not have the complete 8 rib upgrade, can that be part of the issue?
Old 12-19-2012, 09:35 PM   #2
Supercharged SS
Drives: 2010 Camaro
Question. Is this happening on the dyno or just cruising around? I only ask because I had my AC belt get tossed on the dyno. No damage was done and we were spinning the blower absurdly fast. When on the dyno or track I take the AC belt of just in case. I have no issues driving on the street,
Old 12-19-2012, 09:41 PM   #3
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I had an IW 8rib that was out of round, I bought it used from a member here and it had less than 10K miles on it, they fixed it for $50 and rebuilt the entire thing and sent it back to me and all has been fine.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 12-19-2012, 10:04 PM   #4
2010SSRSM6
2010SSRSM6's Avatar
All the issues have been found after street driving. The belts were checked, the car was driven 30 miles when the A/C belt was thrown off taking out the plug and wires.
If it was aggressive driving I could see a little slop causing the belt to come off, but there wasn't any of that this time and it still came off.
Old 12-19-2012, 10:06 PM   #5
Supercharged SS
Drives: 2010 Camaro
[QUOTE=2010SSRSM6;5937008]All the issues have been found after street driving. The belts were checked, the car was driven 30 miles when the A/C belt was thrown off taking out the plug and wires.
Sent from my iPhone using Tapatalk[
Doesn't the AC belt stay on the stock dampner? The one behind the IW?
Old 12-19-2012, 10:06 PM   #6
2010SSRSM6
2010SSRSM6's Avatar
The car has less than 1000 miles on it since it was "checked" by IW and they gave it a passing grade. Obliviously that doesn't mean a hole lot.
It took nearly a month to get it back from IW the last time they had it.
Old 12-19-2012, 10:10 PM   #7
Unreal
Drives: 2006 Z06
Zero issues and I'm sending one back to get rebuilt here next week. Has he replaced the a/c tensioner or looked at the a/c clutch or anything else that could cause it?
Nick
Corvette Z06 -1200ish rwhp
Old 12-20-2012, 04:23 AM   #8
2010SSRSM6
2010SSRSM6's Avatar
Not yet. The car has less than 22k miles on it. It had zero issues until the OD crank pulley went on.
Old 12-20-2012, 09:17 AM   #9
bucketobolts
bucketobolts's Avatar
Drives: 2010 2SS
I tossed my a/c belt yesterday. It just came off and was dangling behind the balanced. I had to remove it to get home then reinstalled. After a test drive and a hell ride, it is still hanging in there. BTW I'm running a new GM belt.
bucketobolts is offline   Reply With Quote
Old 12-20-2012, 10:01 AM   #10
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
I have shredded mine twice in the last couple months. In the spring I will look
into the problem and see if its normal with this much power or if its a
compressor problem. btw I have stock balancer and 6 rib
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 12-20-2012, 02:41 PM   #11
2010SSRSM6
2010SSRSM6's Avatar
That's how we found his on Tuesday. Popped the hood to check the belt and it was thrown off.
Old 12-20-2012, 02:43 PM   #12
2010SSRSM6
2010SSRSM6's Avatar
What power level are you at? With the OD crank pulley, OD rear cogs on the Maggie and the 3.6 front pulley he's right at 11.5 pounds of boost.
Old 12-20-2012, 03:29 PM   #13
quincy speeder
Drives: 2011 Camaro SS
Is he putting on new belts or just re installing the same one?
I've thrown mine a few times while smacking the rev limiter. The design on these new camaro's suck. My Vette has never thrown the AC belt.
2010 SS, 230 Cam, ARH headers,Airaid intake, 160 t-stat,3.90 gears 475hp/430tq. -old setup
added- Procharger F1-D, alky control,FIC 96lb,fuel system- 810hp/735tq- 10.3 at 136mph , 1.75 60'. see how long it lasts.
Thanks to Slowhawk Performance.
2008 C6, 427ci,YSI,mcleod clutch,Alky control, built tranny, custom fuel system. 985rwhp, best 1/4 -9.4 at 152mph. still trying to get the shifting down:(
quincy speeder is offline   Reply With Quote
Old 12-20-2012, 03:45 PM   #14
ayousef
ayousef's Avatar
Drives: 2013 ZL1
this problem is common with OD crank pulleys and doesnt only happen on camaros.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
