Old 12-20-2012, 02:28 PM   #1
LSR SAL
LSR SAL's Avatar
Drives: faster than dirt...
ALL NEW LSR PERFORMANCE CAMARO BUMPSTEER KIT
Uploaded with ImageShack.us
Description
Time to Install
About 2 Hours
Tools Needed
Basic Hand Tools
Difficulty Level
Tech Recommended
If you have substantially lowered your vehicle chances are you have introduced bump steer. What is bump steer? Bump Steer is changes in toe caused by suspension movement.
Every car has bump steer, however when you lower the vehicle you increase the amount of bump steer that occurs, if this becomes excessive you will begin to notice some unwanted vehicle driving characteristics.
When you turn your steering wheel you are essentially changing the toe of the wheels to turn the vehicle. Excessive bump steer is undesireable because it introduces unwanted steering inputs which means the suspension is steering the car instead of the driver.
If your car is lowered and has tracking issues and less predictable steering behavior, you need a bump steer kit.
Our LSR Bump Steer Kit will allow you to correct your bump steer geometry and can do so without requiring you to drill or modify your vehicle spindle.
In addition, our bump steer kit makes a great service replacement for your worn out, high mileage outer tie rods even if you do not have excessive bump steer issues.
Pick up a bump steer kit today and refresh your outer tie rods and improve your steering.
Product Features
Wide range of adjustment
Heat treated after machining to ensure stud hardness
Studs are made to the exact taper of the factory spindle - no modifications required
Direct bolt on installation
Vehicle Fitment
2013 Chevy Camaro 6.2L V8 LS3/L99
2013 Chevy Camaro 3.6L V6
2012 Chevy Camaro 6.2L V8 LS3/L99
2012 Chevy Camaro 3.6L V6
2011 Chevy Camaro 6.2L V8 LS3/L99
2011 Chevy Camaro 3.6L V6
2010 Chevy Camaro 6.2L V8 LS3/L99
2010 Chevy Camaro 3.6L V6
Also offering free shipping!!!
Please let us know if you have any other questions or comments
LSR SAL is offline   Reply With Quote
Old 12-21-2012, 02:49 PM   #2
matt@lsrperformance.com
matt@lsrperformance.com's Avatar
Drives: 2011 Camaro SS
Thanks for the sales on these!! We have plenty left and always take care of our C5 guys!
Thanks again.
matt@lsrperformance.com is offline   Reply With Quote
Old 02-28-2013, 07:35 AM   #3
sycraft
COTW 5/06/2013
sycraft's Avatar
just had these installed and vehicle feels very precise with no unwanted steering feeling. Thanks LSR.
Old 02-28-2013, 07:39 AM   #4
L99CAMA2011
L99CAMA2011's Avatar
I have PFadt radius rod spherical bush and the front trailing arm spherical bush as well that took care of unwanted steering issues but is this kit still stiffer than the stock piece it replaces.
Old 02-28-2013, 04:39 PM   #5
This kit is going to be stiffer than a factory style tie rod end. But the point of this kit is to readjust the angle of the tie rod ends to eliminate bumpsteer. When you lower your car you change the steering geometry and this kit will allow you to put it back in line.
Thanks!
Old 02-28-2013, 07:39 PM   #6
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
Do you have to get an alignment after install?
mhog is offline   Reply With Quote
Old 02-28-2013, 09:40 PM   #7
sycraft
COTW 5/06/2013
sycraft's Avatar
Yes, they replace the tie rod ends, toe will be affected
