Old 12-21-2012, 07:43 PM   #1
Abomb1223
Abomb1223's Avatar
Drives: 2011 Camaro
Purpose of the . .
What is the purpose of the wind diffuser (i think that's what it's called) underneath the front bumper? I recently replaced my front bumper and didnt put it back on, should I?? Thanks!
Abomb1223 is offline   Reply With Quote
Old 12-21-2012, 08:08 PM   #2
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Maybe it is for the cool airflow needed by the radiator? I asked the same thing when I was installing the hide-away front license plate. Only half of the bottom grille is open, but it must have some effect...then again, the mailslot's only purpose is to let us all know it is an SS.
tonyko1 is offline   Reply With Quote
Old 12-21-2012, 08:11 PM   #3
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Its ideally to direct air flow. It is more relavent on the zl1. Not really required unless going extremely fast over 100+
sent from my galaxy s3. that would explain the errors.
xjer22x is offline   Reply With Quote
Old 12-21-2012, 08:13 PM   #4
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
The black strip? I left mine off looks better that way.
Old 12-21-2012, 08:26 PM   #5
tjk_art
Drives: 2010
That's funny. I think it's actually for a more refined look ?
Didn't put mine back on when I replaced with ZL1 front fascia though.
tjk_art is offline   Reply With Quote
Old 12-21-2012, 08:31 PM   #6
Abomb1223
Abomb1223's Avatar
Drives: 2011 Camaro
It cost 50 some dollars so I left it off as well. Just making sure it wasn't too important. Thanks fellas!
Old 12-21-2012, 08:31 PM   #7
Dan1028
Mechanical Engineer
Dan1028's Avatar
Drives: 2012 IBM Camaro 2SS/RS A6
I believe the purpose of the front air dam is mainly to direct air toward the radiator for cooling. GM has been using this design on most of their passenger cars for years. I've always felt that it looks unrefined, as I generally don't see it on other manufacturers' vehicles.
Current Vehicle: 2012 Chevrolet Camaro SS
Past Vehicle: 2001 Honda Prelude SS
LEFT HAND DRIVE
Dan1028 is offline   Reply With Quote
Old 12-21-2012, 08:38 PM   #8
oldfriend
Drives: Fiat 500 E
Diffuser , to divert the air flow from under the car , therefore creating a low pressure under the car which helps to keep the car [ glued ] to the pavement .
I think
Old 12-21-2012, 09:04 PM   #9
Abomb1223
Abomb1223's Avatar
Drives: 2011 Camaro
Necessary?
Old 12-21-2012, 09:17 PM   #10
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Originally Posted by Abomb1223 View Post
Necessary?
I wouldn't be too quick to discount it...It takes a beating from driving...lol..but I think it's worth maintaining...might diffuse air so the flow through the radiator and engine compartment flows better, perhaps even as a stiffener for the flimsy plastic it's attached to...And if nothing else, it acts like a curb feeler for the front end...lol
90503 is offline   Reply With Quote
Old 12-21-2012, 09:19 PM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Depends on the car as it can have several functions. Some are for directing airflow to things such as power steering pump coolers or the radiator. It's also on there to offer some protection against road debris passing under and hitting the underside of the engine such as oil pan. It's made to break away so it can protect somewhat and yet not destroy the front bumper.
The Camaro has used it as a radiator air dam. see below for 3rd & 4th gen
http://www.hawksthirdgenparts.com/pr...r-Air-Dam.html
http://www.rickscamaros.com/camaro-l...1993-2002.html
However for the 5th gen it is called an Air Deflector and not a radiator air dam so it may serve no cooling function on the 5th gen. However they do cause a high pressure air buildup in front of them and cause a low pressure buildup behind them. This very well may aid in directing the airflow for the radiator due to the low pressure buildup behind it.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 12-21-2012, 10:23 PM   #12
Denis
Denis's Avatar
Drives: 2010 SS
Took mine off when I installed my lip. Haven't noticed any adverse affects.
Old 12-22-2012, 01:44 AM   #13
Abomb1223
Abomb1223's Avatar
Drives: 2011 Camaro
Thank you for the links!
Old 12-22-2012, 01:47 AM   #14
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
I hit something in the road and tore it off. I've run my best track times without it so I'm not too worried about it lol.
AdamZ is offline   Reply With Quote
