12-22-2012, 02:14 AM | #1 |
Stock Throttle Body Porting?
Has anyone ported there stock throttle body to 102mm?
or is that to big to go for the stock TB or would i be better off buying a new 102mm throttle body? i just put a supercharger on and i want as little restriction as possible. |
12-22-2012, 07:03 AM | #2 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
I haven't heard of anyone porting a stock TB to 102mm. If you do go to a 102mm TB you will have to port the snout of your supercharger to 102mm as well. I'm not sure how much boost your running but if I recall correctly we made over 10 lbs and better than 650hp to the wheels before we ran out of air and had to switch out the stock TB for a 102mm. That was with a Maggie 2300.
Bryan
12-22-2012, 09:08 AM | #3 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
You cant. There is not enough material. The NW is a billet 102 body with the TPS/Acuator from an OEM 90 to drive it. Make sure you have the bore/heads/cam to support it or it wont do you any real good gains....not just the blower itself.
