Old 12-23-2012, 04:08 PM   #1
plowxman
Starsky
plowxman's Avatar
Drives: 2012 V8 SIM SS/RS
Throttle Body Question
What is the difference between the multiple throttle bodies? I have a 2012 SS V8 Auto
plowxman is offline   Reply With Quote
Old 12-23-2012, 04:13 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
What do you mean? Like the VMax throttle body?
Click to view my build thread
Old 12-23-2012, 04:31 PM   #3
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
If you are asking the different between stock TB versus a ported TB (using either a CNC machine or by hand), the ported TB has these swirl like engravings on the inside of the TB near the lip. It's designed to change how the air flows which is has been known to give better throttle response, but not known to give any HP increase. There is also a difference between CNC and hand ported TB. Simple, don't go with hand ported TB because they are known to be not as effiecient as a CNC and also hand porting can be very difficult to get right. A CNC ported TB you can ensure that you wont have any porting issues. Not sure if this helps at all, but I know there are many others around here that can probably give you a more technical answer if thats what you are looking for.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 12-23-2012, 04:59 PM   #4
Bo White
Bo White's Avatar
CNC is based off of a tested and true hand port.
Hand porting takes skill and experience to get right time after time. There are some ports that can be duplicated by hand but not worth the effort for the market price for said port. CNC has its advantages: time and consistency.
There is HP in both CNC and a proper hand port.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-23-2012, 05:23 PM   #5
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i wont even waste time or money with mods like aftermarket throttle body. but then again i was never the type of person who wants or need maximum power out of my engine.
Old 12-23-2012, 05:29 PM   #6
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Porting of the TB is not usually for adding power but to enhance drivability by increasing throttle response. Increased HP is a side benefit.
The Bird is the word!
Old 12-23-2012, 07:46 PM   #7
Bo White
Bo White's Avatar
I wont either, just port the stock one.
Totalled:
Old 12-24-2012, 04:15 AM   #8
plowxman
Starsky
plowxman's Avatar
So if I get the VMAX Ported TB and send in my core, that would be the best idea??
Old 12-24-2012, 04:42 AM   #9
Bo White
Bo White's Avatar
Sure, I think they have cores already cut. Just call them up or a sponsor that carries them. Pay the core fee and get the fee refunded on returning your stock/unmodified core.
Totalled:
Old 12-24-2012, 09:39 AM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Throttle response will be what you get out of it and you'll feel it. Hp is a no.
Old 12-24-2012, 11:21 AM   #11
snizzle
Recalled user
snizzle's Avatar
Drives: '12 Camaro SS, '18 Colorado Z71
Can vouch for improved throttle response but not power gain.
2012 2SS 45th AE LS3 M6
Borla ATAK Catback
Kooks Stepped LT Headers
CAI Intake
Hexvents
VMAX CNC Ported Throttle Body
RX Catch Can
Hurst Short Throw Shifter
Pfadt ZL-Spec Stage 3 Suspension
Forgestar F14
Tuned by Frost
Old 12-24-2012, 11:58 AM   #12
Bo White
Bo White's Avatar
Properly ported it will give you some power increase.
Totalled:
Old 12-27-2012, 11:38 PM   #13
plowxman
Starsky
plowxman's Avatar
So a VMAX TB would be the best for my buck with a stock engine???
iPhone TapTalk
Old 12-28-2012, 12:17 AM   #14
2012REDSS
Drives: 2012 Camaro SS
If your not going to tune and paired with a good cai it's worth it. If your going to tune LT headers is the best bang for the buck but its considerably more expensive. Just my opinion.
2012REDSS is offline   Reply With Quote
