![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Dec 2012
ZL1 owners with aftermarket exhausts quick question?
I am thinking of adding an aftermarket exhaust to my 2013 ZL1. It sounds good when you are on the throttle but too quiet at idle and take off. I am going to use Zoomers since that exhaust gave me great sound and performance on my 2006 CTS-V. I got so many compliments about how nice it sounded like an "old school" muscle car!
My question is what is done with the vacuum lines from the existing stock unit that operate the butterfly valves? Do you have to plug them. Now that I have your attention any other suggestions you might have regarding exhausts? |
![]() Drives: 2013 SIM ZL1 Join Date: Dec 2012
Have you pulled the fuse for the active exhaust system ?? I did and my ride sounds awesome, IMO.
I Carry!
Drives: 2013 CRT ZL1 Join Date: Jul 2011
I have a Billy Boat, so I re-used the vacuum lines.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540 From Oklahoma, Join us on Facebook https://www.facebook.com/groups/okcamaros/ |
![]() Drives: '13 ZL1 #662; '10 SS; '99 SS Join Date: May 2009
I personally love the stock exhaust noise from this car, but if you need more just do the fuse pull.
Est.1775
Drives: '15 Challenger Hellcat (sold) Join Date: Sep 2009
#6 |
I Carry!
In the trunk, passenger side wall under the carpet, you'll have to remove a couple of plugs and pins to pull back the carpet to get to fuse box, fuses are labeled.
Check out this and you'll get a good idea, very easy to do. http://www.camaro5.com/forums/showthread.php?t=255606
#7 |
![]() ![]() ![]() Drives: 2018 ZL1 1LE and 1991 Z28 Join Date: Jan 2009
Sorry, I just want to be sure...Just pull out the "R2 Exh Flap" fuse and leave it out? And if I decide to put it back, just put the fuse back and it will go back to original without having to do anything else? Thanks a bunch guys.
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
#8 |
I wanted the same answer as I am outside about to pull the F8 fuse out! I will have to wait and see of I get a check engine trigger.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2011
My .02 is change the midpipe. More power and sound all at the same time
2016 2SS
2020 super duty on 37's |
#10 |
#11 |
I may need more than just "pulling the F8 fuse". The question was asked if removing it triggers a check engine code? Pretty easy access to the fuse box not hard just has to be done slowly and carefully.
#12 |
![]() ![]() Drives: 2012 Blk ZL1 Join Date: Dec 2011
From the people on here that have went with a complete aftermarket system the sound hasn't been too different from stock. I think one guy actually said his aftermarket was quieter than stock. To me the exhaust is one of the best things about the car.
#13 |
![]() Drives: '05 OB Neon SRT4, '13 IOM ZL1 Join Date: Sep 2012
I removed the fuse in mine the day after I picked her up in Oct. and I've yet to throw a code.
#14 |
Est.1775
I will be doing a DIY tonight on the fuse pull for those equipped with the NPP.
