Old 01-04-2013, 10:27 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
New! 2010-2013 Camaro V8 SS 6.2L Cold Air Intake System - Polished or Painted Colors!
This isn't a sale thread, but this is a new product release/information thread.
2010 2011 2012 2013 Camaro V8 SS Cold Air Intake Kit - Fits 6.2L - Pre-Painted any Camaro Body Color or Polished
Our direct replacement bolt on 2010-2013 Camaro cold air intake kit comes complete with everything to install on your Camaro in under 15 minutes. Our kit includes:
(1) 2010-2013 Camaro Performance Air Filter
(1) 2010-2013 Camaro Highly Polished Aluminum Air Tube
(1) 2010-2013 Camaro Air Filter Coupler
(1)2010-2013 Camaro Cold Air Intake Installation Kit
On our test car, we saw an increase of 10HP with this bolt on kit. It's a very quick and easy way to add style and performance to your 2010-2013 Camaro V8 SS.
Sale thread for polished here: http://www.camaro5.com/forums/showthread.php?t=269037
Sale thread for painted here: http://www.camaro5.com/forums/showth...66#post5990166
RPI Designs is offline   Reply With Quote
Old 01-04-2013, 08:04 PM   #2
2011camaro2ss rs
Drives: 2011 2ss rs package
well my fist mod is on order as of now. i think this is very well priced i just pais 141.70 total that is tax . shipping to my front door
2011camaro2ss rs is offline   Reply With Quote
Old 01-04-2013, 09:25 PM   #3
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Without the filter isolated from the engine bay and the tube being uncoated metal, isn't this really a HAI? How is the tube/filter suspended?
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-04-2013, 09:40 PM   #4
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
What about the shroud to keep engine bay temps out? Is this just a replacement parts for those with the Cold Air Inductions intake?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 01-04-2013, 09:52 PM   #5
IndeedSS1
IndeedSS1's Avatar
The picture on their website shows just those parts installed. If it had a heat shield and a thick ceramic coating on the inside of the tube it would be interesting, but probably the same price as cai.
Old 01-04-2013, 10:09 PM   #6
SPCBA
Drives: pleather and Chiclets
Originally Posted by IndeedSS1 View Post
Without the filter isolated from the engine bay and the tube being uncoated metal, isn't this really a CAI? How is the tube/filter suspended?
My thoughts exactly where is the box? If there isn't any box/heat shroud than its just an expensive way of adding a cone filter.
SPCBA is offline   Reply With Quote
Old 01-04-2013, 10:56 PM   #7
rberns
rberns's Avatar
Its kind of a cool idea, but like we all said, where is the heat shield and is the tube ceramic coated...if not its a waste. Secondly, if it does come with a heat shield would that be painted too or would that be the aluminum/powder coated look? I think RPI is trying to jump the gun to quickly before getting everything figured out correctly.
Old 01-05-2013, 07:53 AM   #8
IndeedSS1
IndeedSS1's Avatar
I'm just not so sure that they can add the items to make it a cold air intake and still hit the target price point.
Outside of the obvious heat issues, I still don't see any method of securing the tube. Even if you tighten the hose clamps enough to keep the tube in place, wouldn't this put undue stress on the intake manifold TB screw inserts over time?
Old 01-05-2013, 05:27 PM   #9
ssmike
BL1ZZRD
ssmike's Avatar
Old 01-05-2013, 11:32 PM   #10
montreal2010yellow
montreal2010yellow's Avatar
I have a G5CR air intake and I had to put a metal strip just under the filter and attached to one of the EOM screw so it would'nt move. A 50 cents mod. But I have to mention that I have a Nickey Chicago Stinger hood that has a functional ram air that brings fresh air directly to the filter.
This one looks alike but is not the same material quality than the G5CR. Not even close. I don't like where they put the clean side PCV tube just before the throttle body. That will get some oil into it.
Name:  devant sep 2012.jpg
Name:  my car june 29 2012.jpg
Old 01-06-2013, 09:54 PM   #11
2011camaro2ss rs
  • (1) 2010-2013 Camaro Performance Air Filter
  • (1) 2010-2013 Camaro Highly Polished Aluminum Air Tube
  • (1) 2010-2013 Camaro Air Filter Coupler
  • 2010-2013 Camaro Cold Air Intake Installation Kit
it says on there site Polished Aluminum Air Tube not steel.and i can make a shild to isolate it from the heat off the engine.
Old 01-07-2013, 08:49 AM   #12
IndeedSS1
IndeedSS1's Avatar
You might have success with making a heat shield for the tube as well. I have DEI silicone spray and their Titanium header wrap that I wanted to try. Was going to put a thick coating of silicone down, let dry and then wrap all exposed tubing. But I no longer have the intake I was going to try that on.
Old 01-07-2013, 12:56 PM   #13
RPI Designs
That's a good idea. Just to elimnate confusion. This is not any of the competitors designs or parts. This is slightly different than any other intake available. Tube size, harness plug location, filter material, no box, etc.
We've had a lot of guys asking about a box, or heat shield. We are looking at options to do something of this nature, of course it will not look like anything on the market if we decide to make a shield. If we do add a shield, we'll call it a stage 2, price will need to go up as more materials and labor to assemble the kit.
Thank you for your interest. Again, this is not pieces together by any other intake available on the market, this kit uses it's own pieces, made just for this kit with a high performance generic air filter for optimum performance.
Old 09-03-2013, 10:02 PM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
So nothings changed? Just a 8 month bump?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
