Old 01-04-2013, 03:57 PM   #1
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Added X-Pipe and Now.......
So I just had a tru x-pipe installed to complet my exhaust
It sounds great! The only down side is a prominate drone at 1.6K and lower RPM's. Is this normal? If it is than I can live with it by down shifting to keep the RPM's up. Or are the 40 series are too much?
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 01-05-2013, 04:45 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
A set of whistle tips will keep you from hearing that nasty drone. Works better than J pipes and a LOT cheaper.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-05-2013, 04:57 PM   #3
ReoRockStar
ReoRockStar's Avatar
Drives: 2012 Camaro 2LT 45th AE
Whistle tips?
ReoRockStar is offline   Reply With Quote
Old 01-05-2013, 05:06 PM   #4
Missile Man
I tuned out the AFM some time ago. I thought the J pipes were to help with the running on 4 cylinder drone? Does the LS3 have this issue?
Ditto: whistle tips ?
2010 Black 2SS L99
Mods:
* CAI Intake
Old 01-05-2013, 05:53 PM   #5
SPCBA
Drives: pleather and Chiclets
Drone and afm aren't mutually inclusive. You can have one without the other. J pipes cut to the proper length eliminate a desired frequency.
SPCBA is offline   Reply With Quote
Old 01-05-2013, 06:26 PM   #6
naSSty1
Drives: 2010 Camaro SS
I just keep my RPM's up closer to 2000. No drone here. HAHAH
naSSty1 is offline   Reply With Quote
Old 01-05-2013, 07:12 PM   #7
axis
Search Ninja
axis's Avatar
Originally Posted by ReoRockStar View Post
Whistle tips?
J pipes in the proper length and place should eliminate drone at the problematic RPM. There's a formula you use to calculate that. AFM sound is mechanical and can't be eliminated. It can be lessened, but not totally eliminated. Aftermarket exhausts make your exhaust louder. This also makes AFM louder if you still have it enabled. Series 40 FM's are loud and will drone. Typically, the louder the exhaust, the more prone to drone.
Halltech CF 102 fed
Old 01-06-2013, 11:45 AM   #8
Missile Man
Ok, make sense certain rpm's = non desired resonance frequencies depending on the make up of the exhaust system.
Thanks for the info!
2010 Black 2SS L99
Mods:
* CAI Intake
Old 01-07-2013, 01:13 PM   #9
ARK Performance
ARK Performance's Avatar
Drives: Corvette C7
Once the Xpipe is added, drone usually occurs at a lower frequency. If you were to go toward the helmholtz route, it would be shorter.
ARK Performance is offline   Reply With Quote
Old 01-07-2013, 02:29 PM   #10
BigRed585Lbs
Drives: Sierra and Tahoe
Once again, grasshoppers, the "simplified" formula for determining the length of a Helmholtz quarter-wave chamber dealing with the elimination of a known resonance frequency is as follows:
The speed of sound in feet per second (say, 1072feet/second)
divided by
The frequency you wish to eliminate (say, 128cycles/second)
equals
8.375feet/cycle (numbers divide/seconds cancel out)
This is the length of a full wave form; much too big to work with under a vehicle.
To get a quarter-wave length, divide 8.373feet/cycle by 4 to get 2.09373feet/quarter-wave length.
Multiply 2.09373feet/quarter-wave by 12inches/foot to get the chamber length of 25.125".
Tube diameter does not affect frequency, only the amount of attenuation.
This worked back in 2009, and it still works today.
Be sure to use your own target frequency in the formula.
The speed of sound figure is not going to vary enough to worry about. We're not rocket scientists.
REMEMBER: Be sure to use your own target frequency in the formula.
BigRed585Lbs is offline   Reply With Quote
Old 01-08-2013, 10:05 AM   #11
Missile Man
Once again great info! Thanks.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 06-11-2013, 11:29 PM   #12
Deucez75
Deucez75's Avatar
Drives: 2011 Camaro SS convertible V8
Whistle tips?
Topless in Paradise
Deucez75 is offline   Reply With Quote
Old 06-11-2013, 11:42 PM   #13
axis
Search Ninja
axis's Avatar
Originally Posted by Deucez75 View Post
Whistle tips?
Did you totally miss post #7?
Halltech CF 102 fed
Old 06-12-2013, 05:43 AM   #14
woolf
Drives: 2011 SLP SS
Yah, they for decoration! Wha whoo........
2011 2SS/RS LS3 SIM
Hurst shifter. Lowered. SLP 575 Supercharger kit. SLP Loudmouth I. Maybe more to come?
http://youtube.com/watch?v=ezqXXgAnUus
woolf is offline   Reply With Quote
