Old 01-09-2013, 02:10 AM   #1
baggins
Drives: 65 mustang
who makes aftermarket fuel rails for an ls3 manifold and shorty inj.
Ive done a bit of searching and havent found a company that makes an fuel rail kit for a stock ls3 manifold using the shorty injectors... anyone have any ideas? are spacers my only option?
baggins is offline   Reply With Quote
Old 01-09-2013, 09:09 AM   #2
1sikRS
Drives: chevy
Bbk makes a fuel rail set don't think spacers are needed
1sikRS is offline   Reply With Quote
Old 01-09-2013, 09:15 AM   #3
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I'm not sure what you mean by "shorty" injectors, are those like the stock ones, or even shorter? I'm running Aeromotive Fuel Rails with the stock injectors, no spacers needed.
blazzin1 is offline   Reply With Quote
Old 01-09-2013, 10:56 AM   #4
1sikRS
Drives: chevy
Far as I know spacers are only needed w the fast intake becuse of how tall the manifold is and if u reuse the stock rails other then that u should be just fine I'm pretty sure
Old 01-09-2013, 10:57 AM   #5
2012REDSS
Drives: 2012 Camaro SS
BBKs have a small 1/4 spacer between the mounting bracket on the rail and the intake or at least mine do
2012REDSS is offline   Reply With Quote
Old 01-09-2013, 11:02 AM   #6
baggins
Drives: 65 mustang
By Shorty I mean the stock ls3 injector... any pics guys? Thanks
Old 01-09-2013, 11:38 AM   #7
blazzin1
blazzin1's Avatar
Here are my Aeromotive (14115). FYI....they do not come with any interconnect line, you'll have to "fab" up your own.
Old 01-09-2013, 11:53 AM   #8
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Holley makes one that works with the stock intake and injectors.
http://holley.com/534-210.asp
LSX Camaro is offline   Reply With Quote
Old 01-09-2013, 11:56 AM   #9
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
I am using the Mast Black Label fuel rails and they worked with the stock fuel injectors just fine. I later switched to injectors that flowed 103lbs but were the same dimensions as the stock ones.
Contact Lonnie at Lonni's Performance as he sent me the fuel rails and was working on getting a new rails that also fit the stock intake/injectors.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 01-09-2013, 08:12 PM   #10
jcmG8
Drives: G8GT
Holley example
jcmG8 is offline   Reply With Quote
Old 01-10-2013, 11:31 AM   #11
SRT10KLLR
Closer pic of the rails.
Old 01-10-2013, 11:58 AM   #12
Kelly@PCMofNC
Drives: 2010 RS/SS
We make an 'interconnect' for folks who'd rather not do it on their own. Ours is for the FAST rails but I'm sure the others take the same fitting sizes. We can also custom make this for different sizes, or if you'd rather have stainless and blue/red fittings.
FAST Fuel Rail Plumbing Kit
Kelly@PCMofNC is offline   Reply With Quote
Old 01-10-2013, 07:40 PM   #13
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
wouldnt a Y work better than the interconnect line parallel flow better than series
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 01-10-2013, 08:33 PM   #14
blazzin1
blazzin1's Avatar
Doesn't matter, pressure is equal in all directions, doesn't matter how it flows.
