Old 01-12-2013, 04:40 PM   #1
AirManFL
Mid-Florida Camaro Club
AirManFL's Avatar
Drives: 2018 ZL1
O2 Sensor won't break loose
UPDATE:
If you can't get the an o2 sensor out, it is probably because you are trying to remove it after the exhaust manifold has cooled down. The manifold needs to be heated to remove the sensors. Either heat it with a torch, or run the car to heat up the exhaust before attempting to remove.
I ended up only installing one o2 sensor and drove the car until I could get a new one. I had a CEL but the car ran fine.
Installed my headers and got everything 90% back together and I can't even get the O2 sensor to break loose with a pipe wrench and a 4' breaker bar.
So now I'll have to wait and see if my local GM dealer has one in stock on Monday.
Anyone have any ideas? I'm guessing it's a bad idea to start it up without it. Any help?
Rob
AirManFL is offline   Reply With Quote
Old 01-12-2013, 04:43 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Rob
I've read to spray some wd40 or liquid wrench and let it sit overnight. It will work it's way in and should come out easy in the morning. Letting it penetrate for a period is the key. Don't forget to put antiseize on the new ones and the new bolts.
Felix - Sent from my 2SS/RS
FSP tuned: 377/389
Old 01-12-2013, 04:43 PM   #3
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Rob
Most take em out warm
tramtwo posted this on the go
tramtwo is offline   Reply With Quote
Old 01-12-2013, 04:53 PM   #4
driyac
driyac's Avatar
Drives: 2012 45th Anniversary 2SS
Rob
Go to the store and get a torch, heat those bitches up and they will break loose. If not you are looking at $80 a pop for those sensors.
driyac is offline   Reply With Quote
Old 01-12-2013, 04:54 PM   #5
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
heat it at the base of the threads with a butane torch and it should come out.
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 01-12-2013, 05:13 PM   #6
AirManFL
AirManFL's Avatar
Drives: 2018 ZL1
It's pretty much destroyed at this point. I have to buy a new one.
Just wish I could drive my car.
Old 01-12-2013, 05:48 PM   #7
AirManFL
AirManFL's Avatar
Drives: 2018 ZL1
The sensor started coming out easy and got almost a full turn and then locked up. We couldn't even get it to go back in.
All the others broke loose and we took them out with our fingers.
I was looking forward to posting up a video of my new exhaust.
Thanks for the quick replies.
Rob
Old 01-12-2013, 06:58 PM   #8
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Sounds like it's cross threaded.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 01-12-2013, 07:03 PM   #9
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Hook up front two and enjoy... it will smell and cause a CEL but i dont think it will hurt anything. But I'm a risk taker.
Old 01-12-2013, 07:13 PM   #10
CamaroSSpence
CamaroSSpence's Avatar
Drives: 2012 SS/RS 45th
I use a product from CRC called Freeze Out - it is far better than WD40 or PB Blaster for getting through rust. The key is to apply it and let it sit for a few hours. I also recommend using heat as an alternative (or in addition to) the penetrating oil.
2012 2SS/RS CAI, Cat Back
CamaroSSpence is offline   Reply With Quote
Old 01-12-2013, 07:31 PM   #11
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
A lot of times, they are cross threaded from the factory and very hard to get out. It helps to have the specific O2 sensor socket that most auto parts stores sell. Still I would say one out of every 5 customers will end up needing to replace an O2 sensor:(
MarylandSpeed is offline   Reply With Quote
Old 01-12-2013, 07:35 PM   #12
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Use a o2 socket and a impact wrench......like butter son.
Of course install anti seize afterwards.
FASTER than my SS....for now
2500HD (with a couple parts)
Originally Posted by Coyotekiller View Post
I wonder if this could be why my car idles like its retarded...
GaBoy25 is offline   Reply With Quote
Old 01-12-2013, 07:42 PM   #13
C586
Drives: 2011 Camaro LS
That's because WD40 is not a penetrant. Ill never understand why people try spray it on rusty parts and think it will help. It won't. Freeze out is a great product. I'm a huge fan of PB blaster though too.
C586 is offline   Reply With Quote
Old 01-12-2013, 07:46 PM   #14
GaBoy25
GaBoy25's Avatar
PB blaster ='s winning.
Frame that chit and call it official
