Old 01-13-2013, 05:06 PM   #1
wutshotDJroomba
wutshotDJroomba's Avatar
Drives: 2012 Camaro LS/SC
More power.
I'm a bit of a novice when it comes to adding mods for power, I have already added a new exhaust, CAI, and have a tune on the way. Now my question, Is there any way to get more power out of my 2012 LS? Any real suggestions would be greatly appreciated.
wutshotDJroomba is offline   Reply With Quote
Old 01-13-2013, 05:38 PM   #2
SimpleGreen
Drives: 2015 2SS/RS
Spray it or force induct it (turbocharge or supercharge).
I think they are still working on cam kits for the LFX?
It's really pretty high strung from the factory. I mean, it IS a a naturally aspirated 3.6L V6 making north of 300HP.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 01-13-2013, 05:45 PM   #3
wutshotDJroomba
True they get plenty out of that V6, not too crazy about spraying it, will consider the turbo route, just wondering if there might've been something I was missing between going turbo and the current mods I have. I know that there are no headers available for the LFX because of the design as well. thanks for the advice.
Old 01-13-2013, 06:29 PM   #4
SgtPickles69
Team LFX
SgtPickles69's Avatar
Drives: Fast
Do you have Hi-flow cats?
SgtPickles69 is offline   Reply With Quote
Old 01-13-2013, 10:29 PM   #5
wutshotDJroomba
currently no, would it be worth it to get them? I saw a couple of threads on here stating that the difference really isn't that noticeable, assuming you have them, would you recommend? I'm just running an axle back system for the time being...
Old 01-13-2013, 10:38 PM   #6
SimpleGreen
Drives: 2015 2SS/RS
I'll be honest with you, I have all the basic bolt ons in my car....axle back, cold air intake, throttle body, etc and aside from some improvements in low end throttle response my butt dyno hasn't noticed much. Throwing perhaps 20HP on top of 4000 lbs of car (with fuel and driver) simply isn't a drastic change. But it all sure made the car sound really cool and that was a actually a bigger concern to me than making it faster.
Old 01-13-2013, 10:52 PM   #7
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
It would be nice if some adventurer would look into to porting the heads and having a downpipe built for the LFX. I'm guessing there is some power left on the table just by improving the exhaust flow.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 01-16-2013, 05:26 AM   #8
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
I still wanna see a LFX with 3.91's in the a6 or 4.11 in the m6. I imagine that would get us the most bang for the buck.
C-redfly is offline   Reply With Quote
Old 01-16-2013, 09:14 AM   #9
JuanBAMF
JuanBAMF's Avatar
Drives: Black 2012 1LS
What tune did you get?
JuanBAMF is offline   Reply With Quote
Old 01-16-2013, 09:25 AM   #10
bagelluvr
bagelluvr's Avatar
Drives: 2017 SS Camaro
I'll be honest with you, I have all the basic bolt ons in my car....axle back, cold air intake, throttle body, etc and aside from some improvements in low end throttle response my butt dyno hasn't noticed much. Throwing perhaps 20HP on top of 4000 lbs of car (with fuel and driver) simply isn't a drastic change. But it all sure made the car sound really cool and that was a actually a bigger concern to me than making it faster.[/QUOTE]
This is exactly the mods I plan on doing along with rims and front splitter.
bagelluvr is offline   Reply With Quote
Old 01-16-2013, 09:32 AM   #11
AKA-22
AKA-22's Avatar
Drives: ELLE-1
ttt
AKA-22 is offline   Reply With Quote
Old 01-16-2013, 12:33 PM   #12
KMPrenger
KMPrenger's Avatar
The tune should be noticeable for sure. Only mods left for you are a ported T/B and high flow cats. After that, your looking at what should be easily 350 - 360 or more HP at the crank. I say that is pretty dang good for a 3.6 V6 engine.
Past that, you need to look into forced induction if you want more.
Old 01-16-2013, 01:08 PM   #13
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
If you want more power, id say your pretty much almost at the edge. If you want to go faster then you should look into wheels. The 1lt aluminum 18s are a great replacement for the steelies if you want to keep your tires and eliminate a ton of weight. That by itself will probably do as much to your car as all the mods you have right now
Old 01-16-2013, 06:43 PM   #14
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
I shaved off nearly 10 pounds per wheel when I changed mine out. Makes a difference in all things that involve changing inertia: stopping starting, turning. It just feels lighter. I think mine were under $200 each, shipped, through Tire Rack.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
