01-16-2013, 08:07 AM | #1 |
Drives: 2013 Crystal Red Convertible RS Join Date: Jan 2010
Crimping Tool Problems
I'm having trouble getting my quick attaches to crimp to the wire. I'm using T-taps along with a quick disconnects (similar to http://www.ebay.com/itm/150723882441...84.m1497.l2649)
I am trying to use the crimping portion of my "all in one" type stripper tool (similar to http://www.parts-express.com/pe/show...number=360-630) I just can't seem to get the "pinch" to work right - either it's me using the tool wrong, or I just have a cheapo crimper. Can anyone suggest either what I might be doing wrong, or another better tool that will crimp better? Thanks Paul
01-16-2013, 08:11 AM | #2 |
Post a pic if you can. It would be a little easier to see what you are doing and what is wrong.
2010 Summit White SS2/RS
Delivered 08/31/09 |
01-16-2013, 08:13 AM | #3 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
The tool should work with that terminal.
01-16-2013, 08:33 AM | #4 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Those would work, its the same as the one I use, and never had a problem. We don't know how proficient you are in electrical work. Lets assume you don't do much at all or never have. With that in mind, FRIST you are crimping RED spade connections for 16-22 AWG wires. Look at your tool, you see the 3 dots at the crimp? yellow, blue, and red....when crimping a RED connector, you use the RED part so that you will get a good crimp. Now look at the connector, look where the metal is inside and be sure you have your tool over that portion so you crimp it real good.
01-16-2013, 10:58 AM | #5 | |
I'm pretty good with electric/wiring stuff, i don't usually do alot of quick connects, i'm a solder guy. But I've always had trouble with getting a good crimp with this tool. I was trying to make sure I didn't just have the cheapo tool and there was a better one out there. Do I need to pinch until the stop on the crimper touches?
01-16-2013, 11:10 AM | #6 | |
and YES to your last question above.
01-16-2013, 11:28 AM | #7 |
Drives: Love the one you're with Join Date: Sep 2009
First off from someone that has been doing electrical work for over 25 years that universal tool sucks. They are hard to get into tight places and design of them doesn't promote good leverage.
I use a crimper that is designed to do one thing and that is to crimp. With that tool I would use the uninsulated part of the tool just because it will give you more leverage for a tighter crimp. It will crush the plastic on the spade ,but most of time with low voltage that shouldn't be and issue. You could always put a piece of shrinkwrap on the wire before the spade goes on and pull up over the back of the spade once crimped. Also make sure that the wire isn't too small for the terminal that you are using. That can cause crimp problems. Remember though with a car, you're always better to use solder terminals than crimps. |
01-16-2013, 12:00 PM | #8 | |
Paul
01-16-2013, 12:02 PM | #9 | |
Thanks again!! Paul
01-16-2013, 12:04 PM | #10 |
I like this one, but it's a little pricey.
Notice how the insulated part of the crimp in back where the leverage is the strongest. http://www.grainger.com/Grainger/KLE...&cm_vc=IDPRRZ1 Last edited by motorhead; 12-09-2015 at 08:10 PM. |
01-16-2013, 03:42 PM | #11 |
Well O too do like motorhead siggested, I typically use the ininsulated crimp, its much more sucure and if there us an issue I'll ise some shirnkwrap in it.
01-16-2013, 04:05 PM | #12 | |
Car nut
Drives: Tahoe Z71, Race cars Join Date: Aug 2010
Here's one at Home Depot for cheaper http://m.homedepot.com/p/Irwin-10-in...310/202959147/
Quote: Don't you just hate it when Satan steals your ride and does all these weird ass mods to it?
R.I.P. Evan .. A true Friend |
01-17-2013, 07:39 AM | #13 |
I don't see them on your site... How do I order one, and what's the shipping?
01-21-2013, 05:14 PM | #14 |
Update!!!
FYI, got my new crimper and it makes a huge difference. But i was still having problems getting it to really cinch down. So, I took some advice i read that said "Maybe your quick connects are the problem" and amazingly enough, that was my main problem (although, my old cheapo crimper didn't work well with the better connectors). So - lesson learned - 50 quick connectors online on ebay for 6.00 delivered sucks . . . or at least the ones I got did. I used the brand name ones at lowes, and they work great.
Paul
