Old 01-16-2013, 08:08 PM   #1
idealneil
idealneil's Avatar
Drives: 2011 SS/RS And 2011 LT
P0303 Code
My car has been at the dealership for 2 days
Code P0303 is cylinder 3 misfire. They have ruled out everything from computer, injectors coils plugs wires all electrical.
Service Stabiltrak would light up and check engine light flash and turn off after 20 seconds or so with a hard acceleration. But I have no loss of power.
I can reproduce this same code with a hard acceleration everytime.
They have an internalist specialist looking at it tommorow.
This is a 2ss/rs A6 23K miles
Anybody else have any answers or had similiar issues resolved on the V8?
Most of the searches I have done nobody really lets anyone know what the final problem was but I can see where others have had a similiar issue.
I did see a Service Bulletin on the head gasket but looks like it is #8 cylinder
Thanks for any information I can get.
idealneil is offline   Reply With Quote
Old 11-15-2014, 03:48 PM   #2
newcamaroguy7
Drives: red camaro ss 2010
Im getting the same code after new spark plugs
mods: ported tb,1 7/8 TSP lth, adm Cai and scoop, 3:73 gears,exhaust and RPT Tune.
best time before headers: 12.6@111
newcamaroguy7 is offline   Reply With Quote
Old 11-15-2014, 04:10 PM   #3
Gee
Silver Ice
Gee's Avatar
Drives: 2011 1LT Coupe SIM
Loss of spark could be so many things. These engines are known for carbon build up which can cause spark knock. How many miles on her, and do you use a catch can/use seafoam?
Gee is offline   Reply With Quote
Old 10-31-2015, 04:05 PM   #4
GSoccerCam
Drives: 2010 LS3
what did you get for a solution.. same problem even after new spark new coilpack new rail system new injectors and even changed around the spark wires. still cylinder 3 is not working and doesnt go over 140 temp while the others land around 300
2010 LS3 FORGED BOTTOM END. BUILT TOP END WITH BTR COMPONENTS AND A GPI CAM
GSoccerCam is offline   Reply With Quote
Old 10-31-2015, 11:37 PM   #5
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
If you did not remove the plugs when doing the header install, one could be cracked. Same if you removed them, you could have dropped one. Whenever I see this after a header install it is the first thing I think of.
MarylandSpeed is offline   Reply With Quote
Old 10-31-2015, 11:43 PM   #6
derklug1
derklug1's Avatar
Drives: 2016 GT350
It's elementary, and the dealership should know this, but have they done a cam/crank relearn?
"Life is hard, it's harder if you're stupid" John Wayne
derklug1 is offline   Reply With Quote
Old 12-30-2021, 02:58 PM   #7
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
Any solution to this problem? Any updates? Having same problem with mine
Jalberdi99 is offline   Reply With Quote
Old 12-30-2021, 04:54 PM   #8
Jalberdi99
Jalberdi99's Avatar
I got code p0303. Switch sparkplug , coil and cable from cylinder 3 to cylinder 1 to see if the code would transfer to cylinder 1, but it did not. What else could it be? I did the screwdriver test to see if the fuel injector was firing (ticking sound) like the rest and it does. What else could it be? Any help would be apriciated. Battery voltage when cars off it's about 12.5 (around there) , when running it's around 14.something. HELP!!!!!!
