![]() Drives: 13 ZL1, 10 Silverado LTZ, Chopper Join Date: Oct 2011
FARK wiring help.............
Ok, so I got this FARK harness but no where, let me repeat, no where did I find anything about the (2) grayish 5G-X2A wire harnesses that are suppose to connect to the rear speakers. Anybody got a clue about these?
Since there are no instructions included, I guess we're expected to know what to do with them?????????
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
![]() Drives: '05 OB Neon SRT4, '13 IOM ZL1 Join Date: Sep 2012
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
Yeah, follow the above. The directions are lacking in this department. I found some pics on my own to figure this part out. Then I found out mine were wired backward. Fun times.
You mean there is nothing more to it than that? What is the purpose? I thought it was suppose to go somewhere else.
#6 |
COTW 12/3/12
That's all there is to it.
#7 |
What's the purpose of that harness? Do you know?
#8 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
You should have the fark specific instructions in your kit. If not pm me and I'll send you the link so you have it. I have copied the section about the x2a's below for your convenience. Installing those is really easy.
The X2A Jumpers (needed on coupe, not used on convertible) The last thing involved is installing our x2a speaker jumper wires (harnesses with gray connectors). To install these, All you do is unplug each rear 6x9 (at the speaker) and install the x2a (short gray harness) In-Line. That's it Done. BackgroundThe rear Boston 6x9s are bi-amp'd meaning the tweeter and midrange are powered by 2 sets of speaker wires and two channels on the factory amp, not one. Since a 4 channel amp only has two channels available for the rear, we have two options. Either power a single portion of each rear speaker or split the signal and power them both. Earlier versions of the X2A only powered the midrange of each rear 6x9. Further develpment of our of the x2a harnesses (v3.0) allows us to power both the tweeter and midrange of each rear speaker and this is a huge improvement. The power is split at the connector and a small capacitor is installed in the tweeter line to filter out unwanted bass. This makes for a full range speaker set--just like most aftermarket speakers. If you later decide to install aftermarket 6x9 rear speakers, you can simply snip off the ends of each harness and hardwire it to the new speaker using the gray wires. This way you will not have to cut the factory harness to install new speakers. Last edited by Steve@Subthump; 01-20-2013 at 05:46 PM. |
#9 |
![]() Drives: 2013 ZL1 Join Date: Nov 2012
Steve - to drive the sub input on the amp (JL 700/5), a RCA splitter is needed to drive the sub inputs ? Does it matter which channels you use (ie: should you use the rears over the fronts) ?
Thanks. |
#10 |
The 5 ch amp should have a switch that lets you use the 4ch of input already given from the harness instead of having to split off and with another set. If not then that is okay you can use whichever set you like. Personally I would use the front set but that is totally up to you.
#11 | |
If you prefer to use only four channels of input into the XD700/5, set the “Input Mode” switch in the “4 Ch.” position and use the Ch 1 & 2 and Ch 3 & 4 Inputs. In this mode, the XD700/5 will derive its subwoofer channel signal from a sum of all four input signals. The bass will not fade when the signal is faded by the head unit from front to rear. Excellent. Thanks ! -- Lee |
#12 | |
#13 |
Sorry about that. I will have to have a little talk with someone
on monday about getting the right instructions in the kits. Only a few kits were affected so anyone that didn't get the proper instruction card can simply pm me and I'll send the link. No need to go search around or asking, just hit me up
#14 |
![]() Drives: 2010 Camaro 2SS RS L99 A6 Join Date: Aug 2010
Yes, the little paper that comes with the kit does not take you to the right instructions. I read those a bunch of times and never found what I needed.
However, after a lot of searching, I finally found the following link which helped out a lot. Sorry, I was asked to delete the link, plus it doesnt work for me now either. They must have changed it. Last edited by SHWA; 01-22-2013 at 01:37 PM. |
