01-22-2013, 03:53 PM | #1 |
Drives: 2011 Camaro 2SS L-99 Join Date: May 2012
full exhaust with headers question???
I Have a 2011 Camaro 2ss/rs with the L-99 Motor in it & I'm going to get a Full Exhaust soon with headers. I was wondering what else should I do at the time I get them switched??? I'm going to tune it but I was wondering what other mods could I do & should I do when I change the exhaust???? Throttle body???? CAM???? O by the way I plan on keeping the car for along time so I know my build is just going to keep progressing but I use it as a Daily driver so I want to keep it streetable... Not to crazy...
01-22-2013, 04:00 PM | #2 | |
Drives: 2015 2LT Torch Red C7 Stingray Join Date: Jul 2012
An air filter will also be a must and there are a bunch to choose from. |
01-22-2013, 04:04 PM | #3 |
A cam is a great way to add some killer power on these motors. I would ask around on the board and others who have cams about drivability. Some people don't mind a big cam and others wouldn't want to driver it daily. Like mentioned by Mutant Racer above, you can save money by having them installed and tuned at the same time. I'd recommend a cold air intake as well. Also, you might want to look into an LS3 conversion. This will allow you to run bigger cams and remove the dreaded AFM.
01-22-2013, 04:33 PM | #4 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Get the full boltons ie the ones your doing plus a coldair like a rotofab and tune it. Then enjoy it while you save and figure out your end game as far as what your goals are for the car.
Adding a cam in an L99 is more to it. Like are you going to want to go Ls3 conversion? Or delete AFM( which is a must ) and keep vvt? You'll also need a stall which should be a must for any automatic, but that will depend on the type of cam you decide to go with. Just my .2
01-22-2013, 05:47 PM | #5 |
Stroked and blown
Cold air intake intake ... Air in and air out is always the first step. After that you have to plan everything out. NA vs FI ? The answer determines the next step.. You'd don't want to do things twice. Cam is a perfect example cams for NA are a lot different than blower cams.
