![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Dyno Questions ...
Going to a dyno day this weekend ...
#1 What mode or PTM number is best ? #2 What is the safest way to strap the rear, so there are no problems with the ride height sensor rods ? Thanks
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
2. any experienced dyno operator should be able to figure that out.
#3 | |
Thanks, just making sure
![]() ![]() Drives: 2013 zl1 Join Date: Nov 2012
You need to hold the button for thev seven seconds to turn everything off or car will flip out
![]() 2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44 2007 corvette vert ..retired.. 2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far.. |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Ya it shouldnt be a problem. You may have code ABS lights on after the runs because the car will pick up the rear tires are spinning, but the fronts are not. By the time you get out of the parking lot, they should turn off.
#6 | |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
If so - see you there with my ZL1! And glad you asked as I had the same questions! |
#7 | |
Yep, Phil aka Racebum should be there as well
#8 |
Drives: 2012 ZL1, 2009 CTS-V Join Date: Jun 2011
The ZL1 has some really nice places for the straps on the subframe. The dyno operator will have no issue there.
Turn all of the TC nannies off
#9 |
Thanks, that's what I was most concerned with. With the several reports with the sensor rods getting bent, I would feel better double checking the setup.
#10 |
#11 |
![]() Drives: 2013 ZL1 Camaro A6 Join Date: Nov 2012
Where are the sensor rods your refering to and what do they look like? I'm going to the dyno in about 2 weeks. What about the air pressure in tires, any certain PSI?
#12 | |
Go through this thread, he broke both rods while others have had theirs get bent. http://www.camaro5.com/forums/showthread.php?t=269242 Tire pressure should just have to be at 32psi
#13 |
Thanks, will look under car to see if I can remove them so don't have to worry about them getting broke.
#14 |
That was not strapped down correctly. Not all dyno operators were created equally I guess.
The best strap location in more inbound towards and just in front of the pumpkin. |
