Old 06-14-2009, 07:15 PM   #1
BumbleBeeSS2009
BumbleBeeSS2009's Avatar
Drives: Rally Yellow 2SS/RS
To muffler delete or not to delete
What's the benefit from getting an Axle-back exhaust as opposed to a muffler delete?
Looking at the SLP Loudmouth Exhaust...
Wondering if I should just cut the mufflers off and use the 200+ I'd save on something else....
Any help?
#52325 Delivered 11/07/2009
BumbleBeeSS2009 is offline   Reply With Quote
Old 06-14-2009, 07:16 PM   #2
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
If you are doing the Loudmouth I, it will be a similar sound. If you were going to use the Loudmouth II....the delete will not sound the same. The Loudmouth II is a deeper sound.
ZZcamaro is offline   Reply With Quote
Old 06-14-2009, 07:24 PM   #3
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
+1 and less drone
oh yeah whats a 2SS/RT
you might wanna fix that
Gentry78 is offline   Reply With Quote
Old 06-14-2009, 07:39 PM   #4
BumbleBeeSS2009
ZZ looking at the loudmouth I...
Im a bit of a newbie when it comes to stuff like this but from the pictures of the Loudmouth it looks just like a muffler delete...
What am I paying close to $500 for? are they special tubes?
Better off having them cut the mufflers out and go with straight tubes to 4" tips no?
Old 06-14-2009, 08:04 PM   #5
C6Z06dude
Drives: 2009 C63 AMG,06 Evo,07 VW GLI,
I personally never like to cut and weld because I always like to retain the stock parts in case I need to put it back to stock. I guess if you don't care about cutting then I would say just go to a local shop and have them cut and weld, that would be the easiest and cheapest way.
09 Mercedes Benz C63 AMG
12.9@111.04 mph stock at SIR(Tucson 3100ft)
Currently 12.3@118.59 mph with tune , headers and air filters
Previous car> 08 Z06 with cams, heads,headers and other minor stuff
C6Z06dude is offline   Reply With Quote
Old 06-14-2009, 08:09 PM   #6
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
Cutting out the Factory Mufflers and replacing with straight pipe may give you a better sound, but like said above, the highway drone may give you a freakin' headache.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 06-14-2009, 08:12 PM   #7
C6Z06dude
^^^+1
Old 06-14-2009, 08:15 PM   #8
ZZcamaro
In the past the Loudmouth has included chambered pipes. Not normally just a muffler delete. I have not had a chance to look at the new Loudmouth kit in person....But I would stand behind an SLP product 100%. They are great, and I am sure it will be a much cleaner and better fitting install than just a muffler delete.
Old 06-14-2009, 09:00 PM   #9
MikeBing
MikeBing's Avatar
Drives: 2010 CGM/IO 2SS RS
from the two other straight pipe threads, I was under the assumption that there was no highway drone. the rpms are so low that the guys couldn't hear a difference in stock and straight pipe on the highway. Have you heard different? or are you just guessing?
MikeBing is offline   Reply With Quote
Old 06-14-2009, 09:04 PM   #10
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
Old 06-14-2009, 09:07 PM   #11
ZZcamaro
On the highway...I can barely hear the difference in Long Tubes...at Low RPMs the sound insulation in this car works very well (too wlll for me).
Old 06-14-2009, 09:26 PM   #12
2010 CAMARO SS RS
2010 CAMARO SS RS's Avatar
Drives: 2010 Camaro SS RS
just take your car to any muffler shop. theyll do it for 150-400 dollars.
2010 CAMARO SS RS is offline   Reply With Quote
Old 06-14-2009, 09:35 PM   #13
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Well guys I have tried to become some what of a expert in this field. I ran a base line dyno run of 421 hp and replaced my mufflers with polished stainless and re ran on the same dyno no other changes. Dyno now reads 438.6 hp. That shows the factory mufflers are way to restrictive for this engine. After speaking with some engineers at GM they stated these mufflers were indeed very restrictive by design. I will attach the Final dyno sheet as well. There is no drone on the interstate. Only thing I have noticed is a mild pop on deaccelaration which I love.
lawdogg149 is offline   Reply With Quote
Old 06-14-2009, 09:37 PM   #14
ZZcamaro
The pop would be greatly reduced ro even eliminated with proper tuning! Same thing happens with the Long Tubes!
Muffler delete lawdogg149 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-25-2012 11:46 AM
Gained HP from removing mufflers. +17hp (with dyno) lawdogg149 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 06-16-2009 04:14 PM
I.D./O.D. LS3 Muffler Inlets Davis Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 05-07-2009 03:02 AM
A Great muffler for Camaro chewy4ce 5th Gen Camaro SS LS LT General Discussions 1 01-27-2009 03:27 AM
