Old 02-06-2013, 07:46 PM   #1
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
So I cut my filter open...
588 miles of pretty stout break-in miles before the bad weather ended my fun for the year. I changed the oil and filter and cut the filter open with a tool I borrowed from my neighbor. Nothing big in the can. Nothing came out of the pleats with a magnet. When I cut the element out and spread it out however HOLY COW! It makes me wish I never looked. It not like I found a valve spring retainer or anything but there are a lot of little bits and shavings. I'll try to get a pic in the morning but what's normal for a new motor?
I got a juiced up 95" twin cam in my Harley. I ride it pretty hard. 20000 miles or so on the build. I cut that filter open for comparison. Nothing. The filter looked better than the AC though...
So? What say you experienced engine guys? Normal for a break-in filter? I'm guessing so. (Hoping)
chef-beavis is offline   Reply With Quote
Old 02-06-2013, 08:38 PM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Yep, normal. The filter is doing its job.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 02-06-2013, 09:01 PM   #3
chef-beavis
Thanks. I feel better after seeing the other guys pics posted right after I had my thread started. My pieces look very similar. I would have thought they would subside after awhile. Was that 7500 miles example his first oil change or can you find this much crap in the filter from a seasoned engine?
Old 02-07-2013, 09:16 AM   #4
JohnnyBfromPeoria
Typically you might find stuff like that in the first and possibly the second change. Not typical after that.
John B.
Old 02-07-2013, 10:12 AM   #5
chef-beavis
Thanks!
Old 02-07-2013, 10:20 AM   #6
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
After that you are going to see tiny glitter like flakes from normal engine wear. For the first few you are going to get metal bits from machining/assembly and break in that are finally washing through the engine.
This is bad:
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 02-07-2013, 10:25 AM   #7
chef-beavis
Bad after the engine is well seasoned? I have pieces in the first filter that resemble those.
