Old 02-10-2013, 06:02 PM   #1
yellowz
TREMEC6060 1-2 needs fix
yellowz's Avatar
Drives: 2011 2SS/RS
Drag racing wheel hop
I have a 2011 2SS manual trans, with cam and headers making about 450 rwhp. Mostly used as a daily driver but I do about 10-20 trips to the drag strip per year. I definitely plan on adding 18 inch rear wheels and drag radials, and way down the road, possibly a supercharger. I don't care about lowering or looks, unless it helps drag strip performance. I mostly want to get rid of wheel hop and put power to the asphalt while maintaining good street handling. Naturally, I'd like to have all the suspension and driveline upgrades, but for now, on a budget, what suspension upgrade(s) would be the most bang for buck to start with, and what would be next? I'd like to keep it well under a thousand dollars to start with, and then maybe up to a thousand next year for more suspension parts.
yellowz is offline   Reply With Quote
Old 02-10-2013, 06:13 PM   #2
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
PFADT toe rods, trailing arms, subframe bushings. A tad bit over $1000, but if you can do it yourself, it's well worth the money. That should get rid of a majority, if not all the wheel hop.
Frid is offline   Reply With Quote
Old 02-10-2013, 06:56 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Wheel hop is very simply a rapid and repeated loss and recovery of traction. When your car begins to accelerate various bushings and suspension/chassis components deflect. Under normal driving conditions this flexing is negligible but when the car is launched aggressively the deflection causes significant toe changes which reduce the contact patch of the rear tires. This leads to a reduction in traction and momentary wheel slippage which alleviates the toe changes and allows the rear tires to regrip. The vicious circle then continues as the suddenly improved traction again results in deflection and toe changes leading to wheel slippage.
Getting rid of wheel hop is all about limiting the movement of the rear tires in relation to the chassis under acceleration. The main culprits are the rear cradle and differential bushings, rear trailing arms and their bushings, and the toe rods and their bushings. For someone that hits the strip regularly it would be a good idea to go ahead and address the control arm bushings while everything is apart. If you have any questions feel free to hit me up.
Old 02-10-2013, 07:59 PM   #4
yellowz
yellowz's Avatar
Drives: 2011 2SS/RS
Thanks for the advice guys. Google returned tie rods along with toe rods. Are they the same thing? And will rear only work, or is it strongly advised to upgrade the front at the same time?
Asimov's Fourth Law of Robotics: If you don't know what else to do, wave your arms and run around in circles.
Old 02-10-2013, 08:55 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
Trailing Arms and some cradle bushing inserts will be the biggest help. I can tell you that from real world experience. You don't have to use just Pfadt products but they are a very good choice. There are other Mfgs that make good products as well. Toe Rods will help as well but Trailing Arms will give you more of an impact. Trailing Arms don't require an alignment, Toe Rods do.
I would say Pfadt or BMR are the most popular brands for Trailing Arms and Toe Rods used on here. You'll want to change out the bushing where the Trailing Arm connects to the Hub. I would stick to Pfadt for that bushing....BMR's have started to show some issues with higher HP cars. Untill they get that address I would stick to Pfadt for that even if you use BMR trailing arms.
Cradle bushings is right at the top of the list as well. At 450 HP you can still get by with using cradle bushing inserts instead of a full bushing. Much more though and you'll probably want to go to a full bushing. Pedders Street Z kit that has the cradle bushing inserts and radius rod inserts are a great bang for the buck. I tried the BMR style and had a hard time installing them correctly. I removed them after about 2 weeks and went with Pedders and never looked back.
I suggest calling and talking to Jordan over at JDP Motorsports who is also a vendor on here. He is a vendor for all these Mfgs and he can mix-n-match you a great combo to fit your budget. He has first hand experience with racing a 5th gen as well so he can recommend products that work.
BTW: if you do add some Toe Rods you'll have to have an alignment. Make sure to have the guy align your car using the Pfadt or Pedders "Aggressive Street" or "Performance Street" specs.
Build Journal
Old 02-10-2013, 09:05 PM   #6
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
One of the first things i did was the BMR toe rods, & trailing arms and it took 95 % of wheel hope away.
ZOOK is offline   Reply With Quote
Old 02-10-2013, 09:09 PM   #7
John Deere Racer
John Deere Racer's Avatar
Drives: 2013 zl1 m6
Lg motorsports chassis brace
Farks makes anti wheel hop bushings also
2013 ZL1 M6 black on black 10 spokes
592rwhp 616rwtq bolt ons only
www.mikenorrismotorsports.com
Www.lgmotorsports.com
John Deere Racer is offline   Reply With Quote
Old 02-11-2013, 10:54 AM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
If I was in your situation the first parts that I would install would be a good quality set of trailing arms like our BMR non-adjustable with poly bushings (TCA026) and the outer trailing arm bushings. These parts are easy to install and honestly real affordable. This alone will get rid of a good amount of wheel hop but more than likely will not get rid of it. From there I would look into to toe rods (TR002) and the "pro" rear cradle bushing kit (BK031). All these parts combined should take care of pretty much all the wheel hop. Tires will also make a nice positive difference as far as wheel hop goes.
If you want give me a call and we can go over your budget and goals and get you get you set up with a customer package that will work for you and not break the bank.
Kyle
Old 02-12-2013, 02:21 AM   #9
yellowz
yellowz's Avatar
Drives: 2011 2SS/RS
Well thanks a lot for all the information and advice
Camaro5 Forums Rocks! I got the answers I needed just by asking! Now I know what I need and got tips and leads on where to go get the parts. This is so much better than reading magazine ads. You guys are great! I'll be calling some of the contacts, but I gotta wait until the bonus check arrives. I sure hope it's not a "Jelly Bean of the Month" subscription, or I might have to ask cousin Eddie to help out.
Old 02-12-2013, 10:59 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Generally if ask questions around here you will get some good answers.
Like I said if there is any way we can help you out let us know.
Old 02-12-2013, 11:15 AM   #11
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
I would suggest reading the threads about the bushing issue on the BMR trailing arms. Pfadt, nuff said.
-John S.
Old 02-12-2013, 11:18 AM   #12
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
Wasn't jelly bean of the month it was just jelly of the month and its the gift that keeps on giving!
but back to topic, yes this forum rocks! always get great answers. However, this forum makes me want to spend money I don't have! lol
steveo9043 is offline   Reply With Quote
Old 02-12-2013, 11:39 AM   #13
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Good post!
yellowz, feel free to call, PM or email us anytime! We are always happy to answer questions!
Best regards,
Tyler
888-308-6007
Old 02-12-2013, 11:45 AM   #14
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Don't waste your money on aftermarket trailing arms and toe rods. It's the bushings in the stock parts that are too soft not the parts themselves. Get a cradle bushing set, I got the energy one for $150. It does the upper and lower control arms as well.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
drag racing, wheel hop
