Old 02-11-2013, 04:44 PM   #1
burnn1
Burnn1
burnn1's Avatar
Drives: 2011 2LT
Unhappy K&N Replacement Air Filter V6 -> CEL
Just replaced it this weekend and now the CEL is on. Engine has no mods - this is a drop-in filter replacement (not a new air intake). I see threads that the only options are:
1) wait for the filter to dry out a bit
2) replace with a factory filter
any others?
burnn1 is offline   Reply With Quote
Old 02-11-2013, 05:13 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Go to the V6 section. Might get better help there.
Old 02-11-2013, 07:22 PM   #3
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
While the OP does have a v6, it's pretty much the same airbox, and the same filter is used in both the v6 and v8...
That's very interesting that you seem to be having a problem with it OP, have you checked the CEL codes thrown? Also was it BRAND NEW, or did you perhaps wash it, re-oil, and reinstall it wet? You really shouldn't have any problems with it... No vacuum leaks, etc?
Jason@JacFab is offline   Reply With Quote
Old 02-11-2013, 07:59 PM   #4
Bo White
Bo White's Avatar
I agree, shouldnt have any issues with a drop in filter. If it was new it may be over-oiled which is common.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-11-2013, 08:05 PM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Maybe like the other have said above^ and there might be too much oil on the MAF sensor...
Lil' Nasty is offline   Reply With Quote
Old 02-11-2013, 08:07 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Maybe try to pull the battery Without the code there isnt much to say
Old 02-11-2013, 08:31 PM   #7
intensifi
Drives: '12 2LT Convertible
Any way to pull codes like this from OnStar remote diagnostics?
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 02-12-2013, 06:36 AM   #8
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
I have seen new K&N filters blow oil back on the MAF sensor and cause the issue you are having. Pull out the MAF, clean it, and then give it a go.
Hannibal is offline   Reply With Quote
Old 02-12-2013, 07:27 AM   #9
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
This!
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
cel, filter, k&n, v-6
