Old 02-12-2013, 09:35 AM   #1
2011*Camaro*SS
2011*Camaro*SS's Avatar
Drives: 2011 Camaro 2SS/RS Vert
12V outlet not working?
I went to plug in my phone this morning and my outlet in front of the shifter is not working. The one in the center console works fine though. Help please
2011*Camaro*SS is offline   Reply With Quote
Old 02-12-2013, 09:51 AM   #2
family man
Drives: .
Fuse? Maybe the connector behind it fell off?
family man is offline   Reply With Quote
Old 02-12-2013, 10:02 AM   #3
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
more than likely a fuse.
Old 02-12-2013, 10:09 AM   #4
unforgiven
Drives: 2011 ss
start with checking the fuse
unforgiven is offline   Reply With Quote
Old 02-12-2013, 01:22 PM   #5
2011*Camaro*SS
which one is it there are two in the interior fuse box, and they both look fine to me.
Old 02-12-2013, 01:39 PM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
I would suggest going to the dealership if the issue continues. We apologize for the frustrations.
Brandon
Chevrolet Customer Service
Old 02-12-2013, 01:56 PM   #7
2011*Camaro*SS
I cant take it to my dealer because the first time I was taking out that piece I pinched the wire and it ended up getting cut so I had to splice it back together and, im sure thats what they will tell me is the problem. It has worked fine up until this morning. its been spliced together for a couple of months. I checked the splice, its fine.
Old 02-12-2013, 03:32 PM   #8
DangerZL1
Drives: 2023 Black ZL1 Auto
Can you check the splice with a voltmeter? Just because it looks ok, doesn't mean that it is and it depends on how you spliced it together. I'd use crimp connectors if you didn't.
DangerZL1 is offline   Reply With Quote
Old 02-12-2013, 04:10 PM   #9
2011*Camaro*SS
I dont have a voltmeter, and yeah I use a crimp connector then put heat shrink tubing over it. I wonder if I could just run a new wire from the harness. how hard is it? I have 12 gauge wire and the factory wire is 14 gauge..will it work?
Old 02-12-2013, 04:38 PM   #10
DangerZL1
You can go up on wire guage without a problem. If you don't have a voltmeter, an inexpensive 12volt test light available at an auto parts place would work.
Old 02-12-2013, 04:52 PM   #11
poohdogger
Drives: 2011 1ss black on black 6m
The power outlets are on the same circuit its your splice....
poohdogger is offline   Reply With Quote
Old 02-13-2013, 10:18 PM   #12
2011*Camaro*SS
Shoot ill try changing the wire, thanks for yalls help!
Old 02-14-2013, 05:18 PM   #13
2011*Camaro*SS
It was the biggest PITA trying to change those wires so I ordered a whole new factory outlet with a pigtail, when i hooked it up it still didn't work the one in the center console works though...Help please! Where are the fuses so I can make sure I checked the right ones?
Old 02-26-2013, 09:27 AM   #14
2011*Camaro*SS
to my edited question...^^^^^^^^^
