Old 02-12-2013, 10:50 AM   #1
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Trunk Fuse Panel Diagram
Does anyone have the diagram of the trunk fuse panel for the ZL1? I have searched and I cannot seem to find it. I am specifically trying to identify a switched power source in that panel.
Thanks.
Deke736 is offline   Reply With Quote
Old 02-12-2013, 12:33 PM   #2
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
This?
Our Garage:
2018 Traverse High Country, 2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . .
THR ZL1 #1 is offline   Reply With Quote
Old 02-12-2013, 12:36 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Got to love the Owner's Manual
Click to view my build thread
Old 02-12-2013, 01:39 PM   #4
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
That doesn't even look right to me, cause it is missing the active exhaust fuse, this is switched power. Check out my manual mild to wild switch thread
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 02-12-2013, 01:41 PM   #5
SamHouseIII
I Carry!
http://www.camaro5.com/forums/showthread.php?t=255606
Old 02-12-2013, 04:37 PM   #6
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
It's on page 10-48 in the 2013 ZL1 Owners Manual. And yes, it shows F8 as the Active Exhaust Flapper fuse.
Normagene is offline   Reply With Quote
Old 02-12-2013, 04:40 PM   #7
Deke736
COTW 12/3/12
Deke736's Avatar
Thanks guys! I figured it was in the manual, but I couldn't seem to find it!
Old 02-14-2013, 11:13 PM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
It's inside the cover for the fuse box.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 02-15-2013, 12:41 PM   #9
Normagene
Normagene's Avatar
Like to see a pic of your power (pink wire) connections. As soon as the weather warms up, probably another month still, I'll be installing my lights that I got for Christmas. Never heard back from Todd, was hoping he had a diagram of a step 4 connection. Also be nice if they had a u tube video of the install process.
Old 02-15-2013, 09:08 PM   #10
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Thanks.
it is on the inside of the cover?
Skylane765 is offline   Reply With Quote
Old 02-16-2013, 12:45 PM   #11
Deke736
COTW 12/3/12
Deke736's Avatar
I don't know if my application will work for everyone, but I will describe it in detail for you.
Over my Christmas vacation I installed a new amp in place of the factory using the FARK harness from ********. To power an aftermarket amp, the FARK has a remote power wire built in that is switched with the ignition. Typically, the remote turn on wire runs directly to the amp, but I spliced in the pink wire for the Technostalgia tails. The reason I used the amp remote wire is because all of the fuses in the trunk block are constant power and i did not feel like running a line all the way to the front drivers side fuse box. I tested each of them using an multimeter and was surprised to find that out (especially since SamHouseIII showed that the active exhaust fuses should not be- mine were). I measure over 12 volts at every fuse in the trunk panel without a key in the ignition. I should be able to take a pic for you later today showing the spliced wire.
If you do not have an amp remote wire in the trunk, you are probably going to have to run your own line from the front fuse panel back to the trunk. It is not difficult, but it does require removing all the trim panels along the drivers side and into the back seat.
