Old 02-18-2013, 03:36 PM   #1
Terebit
TBit
Terebit's Avatar
Drives: 1973 Camaro Type LT & 2013 ZL1
Wire route through firewall?
Does anyone know a good place to fish wires through the firewall? I'm trying to install laser detectors and need to route wires from the front grill area to a control module under the dash. I was able to route the wire from the rear through a grommet plug in the trunk. Just can't find a spot from the engine compartment.
Terebit is offline   Reply With Quote
Old 02-18-2013, 04:12 PM   #2
bowtiefamily
bowtiefamily's Avatar
Drives: Chevrolet
Look or feel on the drivers side from the engine compartment . Right behind the wheel well up towards the top I found a rubber grommet there.
bowtiefamily is offline   Reply With Quote
Old 02-18-2013, 04:18 PM   #3
gs-63
Drives: Camaro
Do a search for Firewall Passthrough.
gs-63 is offline   Reply With Quote
Old 02-18-2013, 04:39 PM   #4
Terebit
TBit
Terebit's Avatar
gs-63 - - Do a search for Firewall Passthrough.
Thanks! You guys just made my day. I found the pass-through plug just above the battery positive cable. Now, back to work.
Old 02-18-2013, 05:00 PM   #5
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
What unit are you installing? Just curious....
Jeff65SS is offline   Reply With Quote
Old 02-18-2013, 08:05 PM   #6
ZL1ster
ZL1ster's Avatar
Drives: '13 ZL1 IOM M6
+1
ZL1ster is offline   Reply With Quote
Old 02-18-2013, 10:56 PM   #7
Terebit
TBit
Terebit's Avatar
Installed the Passport 9500ix with the ZR4 Shifters.
laser, radar detector, wiring, wiring help
