02-19-2013, 11:11 AM | #1 |
Drives: 2LT Black/Black Join Date: Dec 2009
Rear Right Directional : HELP
My right rear directional is not functioning. I've tried to replace the bulb and its still not working...so I'm assuming it's the fuse. I looked at the fuse box under the hood but couldn't find the corresponding fuse.
Can anyone tell me where the fuse for this is located?? Thanks |
02-19-2013, 11:31 AM | #2 |
Drives: 2013 Blue Ray Blue 2LT Join Date: Sep 2009
I think their is a fuse box located in the trunk behind the carpet on the r/h side.
02-19-2013, 12:33 PM | #3 | |
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043 Join Date: Oct 2008
So, near as I can tell, each fuse controls either: all the plugs in the entire BCM, or just a single plug in a single BCM. If that's the case, then a blown fuse will turn off more than that one lamp; it should black out numerous things. So, it could be a plug issue. Do you have a continuity tester or multimeter to check power @ the plug? See page 9-45 / 9-47 in your manual.
02-19-2013, 03:37 PM | #4 | |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
02-22-2013, 08:25 AM | #5 |
Thanks for the help. I will try the weekend
