Old 02-19-2013, 06:07 PM   #1
47AJV8
Drives: A White Car
How long will the stock motor last supercharged?
I was wondering if anyone could give me a rough idea of how long the stock motor will last if driven normally daily, thrashed a little bit on the weekends, and I put about 15K miles on it per year. And I mean supercharged with the ECS kit and a custom tune (on a 6 speed manual) so ~600-650RWHP, also with ported intake manifold and 3" high flow cat back, any ideas? thanks! (it will never be tracked or taken to the drag strip either!)
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
Old 02-19-2013, 06:13 PM   #2
blufin
blufin's Avatar
Drives: Fire Engine
For the life of the car, with the right tune.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 02-19-2013, 06:15 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I drove mine for over 9K miles before I upgraded the cam. It can last as long as you need it to as long as you take care of it. You just need to be prepared for a "just in case" moment. There's no definitive answer to this question.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 02-19-2013, 06:29 PM   #4
kissmyss03
kissmyss03's Avatar
Drives: 2011 Camaro SS 2SS/RS
when I had my blower on my gto, I drove it hard , and on long road trips without worry. with the correct set up/tune its fine. its when you are really pushing the hp and limits that you may have issues. why do you think SLP offers a 5 yr warranty on their stage 1 , 2 , or 3 kit. confidence in their product and results
2011 Camaro 2SS/RS M6
Kooks Headers, catless mids, corsa exhaust, rotofab intake, SLP TVS 2300, 3.2 pulley, blower cam, cts-v fuel pump, Vector tuned 622 RWHP 573 TQ
kissmyss03 is offline   Reply With Quote
Old 02-19-2013, 06:36 PM   #5
rdblan2
Drives: 2SS RS
The answer is "it depends". A lot of that is on the tune. Have a backup plan.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 02-19-2013, 06:40 PM   #6
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
Have a 179,000 miles on a supercharged engine and still running good.
Beescuz is offline   Reply With Quote
Old 02-19-2013, 06:53 PM   #7
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
It could run well forever or take a shit on you a week after you get it. All depends on the tuner. A tune makes the car.
Frid is offline   Reply With Quote
Old 02-19-2013, 08:41 PM   #8
CyberPredator
50 Shades of Prey
Drives: TT/SS
if tune is right and octane is right and fuel system is supportive. I'd say quite a while. after 20000 and 1.5 years I'm taking mine out of the car and leakdown and compression test were both good at 700whp. (building erl for more power) After finding a decent tuner the next biggest trick is having good fuel. Sometimes 93 just isn't 93. Personally when I plan on beating the snot out of it I put a few gallons of 104 into the mix.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 02-19-2013, 10:40 PM   #9
47AJV8
Drives: A White Car
Okay, so a lot of it's about the tune, where I live only 91 octane is available (no E85 either), and I really don't want to run water/meth injection, would that effect engine life?
Old 02-19-2013, 11:01 PM   #10
Jessika
Drives: Anything Blown
Respecting the boost will ensure that you don't stress the internals. If you are satisfied with 120-140rwhp out of the box then the odds are that your engine will have a nice long life.
The manufacturers even offer 100k mile warranties on their 'stock' systems.
Jessika is offline   Reply With Quote
Old 02-20-2013, 02:44 AM   #11
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
The thing about that is: No IF what comes out is actually 91. Sometimes the pump puts out a lower octane than stated and that's when the engine gets hurt.
Adding a couple gallons of high octane gas (100oct+) from your house when you're going to rip into it will prevent the bad gas issue.
That warranty only works if you don't add anything else such as LT's or a CAI and use the SC manufacturers boxed tune with it. Also if you noticed he already stated he's aiming for 600-650rwhp. Well over the sc base system.
K32 Camaro is offline   Reply With Quote
Old 02-20-2013, 04:43 AM   #12
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
JENNETTY RACING
http://www.google.ca/url?sa=t&rct=j&...pw6GGh4tHk00gw
CHECK OUT THIS LINK TO RPM MAG
I only have 91 in my area as well
ZOOK is offline   Reply With Quote
Old 02-20-2013, 09:06 AM   #13
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
91 is low for a boosted 6.2. You'd have to have some timing backed out of the tune. But yourself some octane booster and put half a bottle in each tankfull. Get you up around 93-94.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 02-20-2013, 09:36 AM   #14
East Coast Supercharging
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
The key is fuel quality and the tune for the most part. You can have the best tune in the world but if you accidentally fill the car with regular and race it hard it could be done right there, or you can be like some of our customers who have well over 100,000 miles on the car after it has been supercharged.
East Coast Supercharging is offline   Reply With Quote
life, motor, supercharged
