02-20-2013, 08:55 PM | #1 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
1LE Struts/ Shocks versus FE2,3,4 Struts/shocks
I know the rears are a monotube type and the fronts are valved different, but looking for a resident "pro" to explain the differences and advantages of making the switch. Mine are in the garage waiting on the springs to get here for the install thread.
02-21-2013, 09:28 PM | #2 |
COTW 5/06/2013
bump
02-22-2013, 09:31 AM | #3 |
Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Well after changing mine from FE3 to FE6 on the 1LE the ride is very firm. You can really feel that the valving is much more aggressive than the standard SS. There's also much more control over the weight of the car with these struts and shocks. Its a great alternative for those looking to improve handling but don't want to spend the money for coil overs.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. |
02-22-2013, 12:44 PM | #4 |
Drives: 2011 Camaro 2SS L99 Join Date: Jun 2011
How would these improve the handling and ride quality on a 2011 ss with BMR 1.4" springs all the way around?
I can tell my stock struts / shocks can't handle the ride height. |
02-22-2013, 02:11 PM | #5 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
None can really, they make the springs to work as good as they can with the shocks. My fe4 shocks work well to control them without being stiff. I would think these will just be a stiffer ride but quicker to react as designed. Still will have the aburpt spring action to bumps and the less travel problems though
02-22-2013, 03:39 PM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
The 1LE dampers have a more aggressive damper map. If you would take the time to measure you ride heights Pedders style, I can comment on ride quality. You'll need a level place to measure, 1/4 tank of fuel and the car as empty as it was new.
02-22-2013, 07:42 PM | #7 |
How do you measure Pedders style exactly?
02-22-2013, 07:58 PM | #8 |
02-22-2013, 08:46 PM | #9 |
25 3/16 front left
25 2/8 back left 25 1/4 front right 25 1/4 back right Car in garage |
02-22-2013, 08:48 PM | #10 |
Well crap, car is about 75% full of gas. Ill measure again when fuel is down.
02-22-2013, 08:59 PM | #11 |
02-22-2013, 10:49 PM | #12 |
20" stocks
02-23-2013, 10:42 AM | #13 |
From what I am seeing on another post it may be too low from a ride quality stand point?
02-23-2013, 11:23 AM | #14 |
You sir are LOW.
OE is on average Front 690mm Rear 700mm 690 -641 ____ 49mm or 2" lower than OE 700 -641 _____ 59mm or 2.3" Lower than stock The upgrade from OE V6 damping and a reduction in drop from2" to 1.5 will absolutely improve your ride and handling. One last question. Aside from the 3/4 tank of fuel is there any other additional weight in your 5th Gen? i.e. 2,000,000 watt stereo, dead bodies, bricks |
