02-21-2013, 08:11 PM | #1 |
ROAD COURSE JUNKIE
TPMS ISSUES
I put on 8k and replaced the rear tires. No TPMS issues when I replaced the tires. At 24k I replaced all four. Ever since then I have had the damn TPMS going off. I have brought it back to the tire shop several times. They reset the sensors several times, then took the tires off the wheels and checked all the sensors, then reset them a couple more times, then replaced them all. Still having issues with the TPMS going off.
Any ideas or someone that has had a similar issue? Maybe my car doesn't like the sensors they put in? Is there really a difference in sensors? I don't want to take it to the dealer since I know they will just blame the tire shop and charge me for it. Any advice or input would be appreciated!
02-21-2013, 08:58 PM | #2 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
I'm thinking they didn't calibrate something correctly somewhere or hit something on one of the TPMS because they communicate wirelessly on their own not synchronized so one not working would generally mess with the ECM?
Not sure just a thought though.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
02-21-2013, 09:20 PM | #3 |
Drives: 2011 SS ZL427 Join Date: Feb 2013
Its to my knowledge that the TPMS sensors once reset they will need calibration by the Tech 2 scan tool by the dealer or someone who has access to that tool so the cars computer will recognize the sensors and to which wheels location their in, How did the place that changed your tires "reset" the sensors?
02-21-2013, 11:06 PM | #4 | |
ROAD COURSE JUNKIE
02-21-2013, 11:11 PM | #5 |
ROAD COURSE JUNKIE
I can only think they are doing something wrong I am not sure. They have reset it several times and replaced the sensors so I have no friggin clue.
02-22-2013, 12:01 AM | #6 |
Sounds like they damaged a sensor, then replaced them with the wrong ones. Did they use OEM sensors? From reading the threads here about sensor problems, seems most get fixed by using OEM sensors.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
02-22-2013, 12:03 AM | #7 |
ROAD COURSE JUNKIE
I was thinking the same thing, figured they used some off brand and my car doesn't like them. But I know nothing about TPMS.
02-22-2013, 06:35 AM | #8 |
Drives: Camaro SS & ZL1 Join Date: Sep 2011
The first question I would ask is if the replacement sensors are GM OEM. If not, demand them to replace the sensors they put in with OEM parts. You will have nothing but problems with anything other than the OEM sensors.
02-22-2013, 06:52 AM | #9 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Also, use the factory valve caps, they actually have a high content of carbon and act as an antenna . A weak battery will also cause them to lose signal.
02-22-2013, 08:03 AM | #10 |
Theres no reason why they should have replaced all the TPMS sensors for replacing your tires unless one or more of them was damaged during dismounting of the old tires or remounting of the new ones, However im wondering if they used OEM sesnors in the event they broke one or more, aftermarket ones some cars can be real funny about aftermarket parts, im some cases they just plain dont fit right or the computer wont recognize them and there for keep turning your tire light on, I would find out if they cant get this straightened out if they replaced them with ones direct from chevy and not autozone.
02-22-2013, 02:48 PM | #11 | |
Drives: GM Vehicles Join Date: Jun 2010
I’m sorry you are experiencing this issue. I agree with the other posters, it sounds as though there is an issue with the sensor(s). Either they were not programmed properly, damaged or the wrong ones were used. I encourage you to consult with a certified technician at your local GM dealer for additional assistance. They will be able to offer an official diagnosis after inspecting the vehicle. If you need assistance setting up an appointment, please PM me your information. Louis (assisting Brandon) Chevrolet Customer Service
02-22-2013, 03:31 PM | #12 | |
ROAD COURSE JUNKIE
I appreciate the response but please read my first post. I am not taking the car to a dealer since they will charge me for something I have already paid for.
02-22-2013, 08:20 PM | #13 |
I tend to agree with you on this, but, something to consider is that a dealership has tools and diagnostic equipment to pinpoint your problem that the typical tire shop does not have. It might be worth considering the dealer if your frustration level with your current shop goes up as it probably will. Most tire shops I have seen will typically throw parts at a problem until it's fixed. They might not charge the customer for this, but the customer gets frustrated in the end because he continues to have to return for more repairers, which increases the likely hood that some bozo will really screw something up.
02-22-2013, 09:11 PM | #14 | |
ROAD COURSE JUNKIE
