Old 02-23-2013, 07:35 AM   #1
BigVic
Speed Racer
BigVic's Avatar
Drives: 2022 LT1
Installed Rockford Fosgate powered subwoofer
Well, I finally upgraded my 2012 1LS non-BA system with a simple powered sub install for the trunk. I went with the Rockford Fosgate Punch P300-10, It's a 10 " sub.
The sub is great, I really like it. It was around one hundred fifty bucks shipped at Sonic Electronix.
http://www.sonicelectronix.com/item_...e-P300-10.html
http://www.crutchfield.com/p_575P300...10.html?tp=114
Here is a link to the manual/instructions for the sub:
http://a248.e.akamai.net/pix.crutchf.../575P30012.PDF
The install was super easy. Pos to battery, neg to bolt in trunk. Used speaker level inputs. I tapped into the rear speaker...easy. I did not need a separate turn on wire, as the sub turns on when an incoming audio signal is detected , and off when no audio signal.
No line output converter is needed. Just connect the pos/neg from the sub to the pos/neg of your rear speakers. I just used a t-tap so I didn't even cut the wire.
Here are the colors for the +/- for both the rear non-BA speakers (option code UQ3).
Left (drivers rear):
(-) Yellow
(+) Brown
Right (pass. rear):
(-) Light Blue
(+) Dark Blue
The only thing I needed to run up front is the PNC rotary control. Controls the bass level. It is optional, but it's a no-brainer install so you can fine tune the bass. If not, all the controls for boost/output would be in the back.
It also fits perfect. Push it all the way back, and it fits perfect, like it was made for the Camaro. Just used a little velcro. I'll post a pic later.
The sound is very good, and I can easily make the rear view mirror shake. Glad I made the purchase. It gives the stock stereo that missing low end punch that was missing without spending all that much.
Forum user Hayden installed the 12" version, and he is also quite pleased.
2022 Summit White LT1 - 6.2L, M6, Dual Mode Exhaust, RS Package, Red Calipers, Red Seat Belts, Red Knee Pads, Black Bowtie Badges, Decklid-Mounted Rear Spoiler
Post delivery - FR 41 ZL1 Replica Rims (20x10 Front, +23 - 20x11 Rear, +43), Llumar 28% Tint, Ceramic Paint Coating, Hardwired Uniden R3 Radar Unit and Viofo A129 Dashcam, TMG A-15 (dual) front Laser Jammers
BigVic is offline   Reply With Quote
Old 02-23-2013, 11:30 AM   #2
Hayden
You serious Clark?
Hayden's Avatar
Drives: 2012 Summit White 2LS
Ill take some pictures and throw it up on here maybe even a video
Still working on the permanent positioning.
Hayden is offline   Reply With Quote
Old 02-23-2013, 03:56 PM   #3
BigVic
Speed Racer
BigVic's Avatar
Drives: 2022 LT1
Pics of Sub
Note how well it fits...it was perfect.
Old 02-23-2013, 04:06 PM   #4
Hayden
You serious Clark?
Hayden's Avatar
You weren't kidding about the perfect fit! If mine was just a little wider than it was tall It would have been nice to have it sit up like that!
Old 02-23-2013, 05:09 PM   #5
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
Wow. That looks great
Frid is offline   Reply With Quote
Old 02-23-2013, 05:24 PM   #6
BigVic
Speed Racer
BigVic's Avatar
Drives: 2022 LT1
Thanks Frid
Old 02-23-2013, 06:18 PM   #7
Hayden
You serious Clark?
Hayden's Avatar
Added a video Hard to really show the true sound though.
Old 02-25-2013, 01:09 PM   #8
sanjosebmx
sanjosebmx's Avatar
Drives: 2011 2SS Synergy Green
has anyone installed this with the BA system? Looks almost too easy?
sanjosebmx is offline   Reply With Quote
Old 02-25-2013, 02:55 PM   #9
Hayden
You serious Clark?
Hayden's Avatar
Not sure why it would be any different. Tapping into the rear speaker. But I'm sure someone with more knowledge will tune in.
Old 03-06-2013, 03:50 PM   #10
sanjosebmx
sanjosebmx's Avatar
I'm putting one of these in this weekend.. got it from amazon shipped for about 200 bucks including tax...
Old 03-06-2013, 05:18 PM   #11
Hayden
You serious Clark?
Hayden's Avatar
Sweet, super easy.. Still enjoying mine!
Old 03-06-2013, 08:36 PM   #12
MrGs SS
MrGs SS's Avatar
Drives: 2013 Black SS/RS
Looks great, would love to hear it. Its a reasonably priced alternative to some of the other set ups I have seen.
2013 2SS Black~ L99
Performance Mods-CAI intake, APEX washer bottle relocate and scoop, Ported TB. SLP 160 degree stat, Norris Catch-can, Pfadt Tri-Y headers, BMR F/R sway bars and Arms, Corsa cat back exhaust.
Appearance Mods-Blackout kit (markers, tail lights), black tail light bezels, black chrome trunk lettering, LSR billet engine dress-up kit, sub box. Billet tensioner pulley and thermostat housing (Billetcustom), Heritage grille.
Tuned by Matt @ Florida Speed and Power
379/388 Mustang dyno
MrGs SS is offline   Reply With Quote
Old 03-07-2013, 06:31 PM   #13
sanjosebmx
sanjosebmx's Avatar
Installed, some trial and error on the BA rear speaker wiring.. but it works, and sounds great. Gives me just the punch I needed..
Old 03-28-2013, 07:41 PM   #14
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
What about installing this with the ******** harness? I'm looking at doing the 12" model. And I figured the ******** harness would make it much easier. Supposedly it's just plug and play and it gives you remote turn on with a set of RCAs.
45thCamaro is offline   Reply With Quote
