Old 02-23-2013, 10:10 AM   #1
ayousef
ayousef's Avatar
Drives: 2013 ZL1
what makes our cars soo damn heavy??
Trying to find excuses for why our cars are pigs but I cant, where is all the weight coming from? I come from a world of Corvettes, and those are some of the lightest sport cars you can buy without having to rob the bank, so what happened on the Camaro?
I was doing a power to weight calculation and for a corvette to hang with a 1000bhp camaro, it only needs 800bhp, and this is not even factoring in for aerodynamics and other variables.
what do you guys think? Has anyone done anything for a STREET camaro as far as weight reduction goes? I know there are some threads but those involve making it more of a race car.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 02-23-2013, 10:24 AM   #2
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
It's been asked a zillion times already. But basically 2 reasons. 1. They took an existing heavy platform and created the Camaro out of it, 2. safety regulations for crash protection.
Next gen will be based on a lighter platform and will probably be 5 to 8 hundred pounds lighter.
The Bird is the word!
Old 02-23-2013, 10:26 AM   #3
ayousef
ayousef's Avatar
Drives: 2013 ZL1
Okay, so what makes it heavy, is it something that could be worked on to take weight off the car? Im stilll looking at a full dry carbon body but that will cost the price of a new car itself.
Old 02-23-2013, 10:29 AM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
The platform is designed for larger cars. Larger sedans and such are usually built off if it. The next Camaro will share a platform with the ATS Caddy which is much lighter then the current Camaro.
Basic weight reduction is possible but it depends on what you feel you can take out of a car and still live with. Living in Dubai I doubt you want to live without the A/C but removing it saves a ton of weight. If you plan on drag or road racing the car and don't car about its drivability you can remove tons of weight. The radio, speakers, carpet, padding, rear/passenger seats, spare tire/jack, bumpers, heater core, power steering (add a manual rack), airbags and plenty more. Do a search on weight reduction. Pretty sure there is a post where someone listed the weights on most of these items as well as a bunch of other stuff you can pull out.
Juiced1 is offline   Reply With Quote
Old 02-23-2013, 11:19 AM   #5
Angrybird 12
I guess if you're not concerned about wercks you could remove the bumper bars.. and then you could also change out the exhaust for a aftermarket, i heard many will save from 50 to 75 pounds in weight. even an Axel Back system will save weight because the big stock mufflers weigh so much.
You could remove the back seat if nobody uses it and make a carpeted panel to go in its place.. if you have the air compressor remove it.... you can remove as many of the creature comforts you could bear to do without.( being your in Dubai I doubt you would want to remove the AC.).. You could change the front buckets to Carbon Fiber Racing Seats... Its all what you decide what you don't need...
Old 02-23-2013, 12:17 PM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
it is the chassis. very safe and rigid platform but very heavy. that extra 1000lbs is going to need 150-200hp vs a vette.
the truth is that adding power is way cheeper than reducing wieght.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
Old 02-23-2013, 12:34 PM   #7
KKreme15
KKreme15's Avatar
Drives: C6 Z06
ZL1 mufflers aren't big and don't weight a bunch
KKreme15 is offline   Reply With Quote
Old 02-23-2013, 12:35 PM   #8
KKreme15
KKreme15's Avatar
Drives: C6 Z06
ZL1 doesn't come with a spare tire/jack
Old 02-23-2013, 12:38 PM   #9
HDRDTD
The Vette also makes use of higher tech and lighter (and more expensive) materials to help save weight.
Old 02-23-2013, 01:36 PM   #10
Ciscokid
Drives: 2013 ZL1 Vert - BRM&2014 NRB Vette
Get new doors.....sorry just had to toss that out.
Ciscokid is offline   Reply With Quote
Old 02-23-2013, 01:39 PM   #11
midnighter
Drives: nothing
Our big butts.
Old 02-23-2013, 02:27 PM   #12
DrkPhx
DrkPhx's Avatar
As mentioned above the 5th gen is inherently heavy because of the platform; however the extra weight of the ZL1 comes from the supercharger and related hardware along with the beefier rear end/suspension, diffuser/splitter/rocker panels, brlly pan and MRC components.
Old 02-23-2013, 02:38 PM   #13
knowitman
Camaro fan since birth
knowitman's Avatar
Drives: 2013 ZL1
The overall dimensions of the car make it heavy. It is a very wide car and has a long wheelbase for a coupe. Just a couple of inches on length and width can add a lot of weight. Compare the width and wheelbase to that of a 4th gen. The wheelbase is nearly a foot longer, and the car is over an inch wider. Since that era, safety regulations have added to the weight as well as the fact that the Zeta platform is a much stiffer platform. The independent rear suspension adds a lot if weight over a solid rear axle.
knowitman is offline   Reply With Quote
Old 02-23-2013, 03:33 PM   #14
Mick1
Drives: 2013 2SS LS3
IMO, American muscle cars are supposed to be big. That's what so cool about them
Mick1 is offline   Reply With Quote
