Old 06-17-2009, 12:38 PM   #1
Wingnut
GOT IT....LOVE IT!!!
Wingnut's Avatar
Drives: 2010 2SS, Silver Ice
CAI vs new filter instead of box at end
Not trying to take business away from CAI aftermarket shops, but won't sticking a K&N custom fit filter on the end of the existing duct work and installing a heat shield/duct to the front do the same thing for the performance? I think I'll give this a shot and have it but on the dyno. Filters are less than $100 and I can make a cool shield in my metal shop.
2SS, Silver Ice......delivered June 10th!
Wingnut is offline   Reply With Quote
Old 06-17-2009, 01:06 PM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Do it .. keep us all posted ! Im a little disapointed by the lack of air intakes currently offered. I don't want to install a true CAI (installed out of the engine bay) as some of the NASTY Rain we get here in Texas can be a problem for a filter installed low on the car ..
Crowley
Crowley is offline   Reply With Quote
Old 06-17-2009, 01:09 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Crowley
I've seen the filter tucked in the lower grill and heavy rainstorms will not be good especially for a daily driver car...
Old 06-17-2009, 01:10 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I haven't seen the inside of a stock air cleaner, but I know there are restrictions in the baffles on the inlet tube juse before the throttle body. It's my belief that gains may not be as much as replacing this tube too.
Does anyone have any shots of the inside of the air cleaner? I know there is an intake duct behind the headlight, but don't know of any baffling within. I know that simply replacing the filter on LS1 F-bodies didn't do much for power because the baffles and shape of the OEM intake, in front of the MAF, really disrupted air flow and replacing the lid for one eliminating the baffles and smoothing the transition in shapes really helped flow and performance. I think this will probably be the case here too.
Good luck and keep us posted. Only the dyno' will tell
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 06-17-2009, 02:07 PM   #5
Wingnut
Wingnut's Avatar
I beleive its the factory ducting from the grill to the box, the box itself and a lousy filter that creates 99% of the restriction that a CAI opens up.
The mod will be a single six inch long pipe that goes from the current flex hose that connects the box with a sensor mount and a two sided heat shield(like those seen on other kits) with custom K&N filter.
I will post pics and dyno results when done.
Old 06-17-2009, 04:50 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cool. I'd like to see the results. If you have pictures you can share, I know I'd appreciate them
Old 06-20-2009, 01:12 AM   #7
JHart
I haz camaro again :)
JHart's Avatar
Drives: 2010 Chevrolet Camaro 1SS
where the CAI gets it's sound is mostly from the deletions from the resonator boxes on the stock pipe going to the box.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd)
2010 camaro1ss(sold, missed, will have another someday)
JHart is offline   Reply With Quote
Old 06-20-2009, 02:02 AM   #8
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
well volume is only half the other half is velocity witch is slowed down by the resonators, so yes i do believe you will see gains but you might just get a little bit more by replacing the entire tubing
can't wait to see the dyno results
Gentry78 is offline   Reply With Quote
Old 06-20-2009, 07:51 AM   #9
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
You could plug the resonators with some RTV easily enough...
patriotpa is offline   Reply With Quote
Old 06-20-2009, 10:57 AM   #10
novajess1972
I Done Caught Diabeetus.
novajess1972's Avatar
Drives: 1972 Chevelle SS/2010 Tundra
Reeeeeeeeeesults??
CANCELLED ORDER: 1SS/CGM/MN6/BLACK RALLY STRIPES
novajess1972 is offline   Reply With Quote
Old 06-20-2009, 11:00 AM   #11
NickPic
NickPic's Avatar
Drives: 2006 GMC Sierra 1500HD
with a CAI u benefit from the pipe also. its usually smoother and lest restrictive
06 gmc sierra 1500HD: w/ 6.0, K&N CAI, air raid TBS, pacesetter ceramic coated LT headers, magnaflow X-pipe, SLP loudmouth I resonators, gibson 4' tips, blackbear custom tune, 20 inch rims, bfg 33" tires, 2-10" mtx subs, 2000 watt audiobahn amp, 10 farad tsunami cap, HID's, air horns etc......
http://www.cardomain.com/ride/3103872
slp tuned diablo programmer for sale. pm me for info.
06 pontiac G6 GT: bone stock except hid's
NickPic is offline   Reply With Quote
Old 06-20-2009, 03:44 PM   #12
JHart
JHart's Avatar
i think utilizing the stock box with a K&N filter and making the tube with no resonators would be the best bet if your not wanting a CAI, but the tube with the open element filter is going to give you the best results.
Old 06-22-2009, 03:29 PM   #13
ZYA_LTR
Drives: Waiting to be ordered
Getting rid of the resonator's on the tubing from the box to the throttle body will help, and either deleting the air filter box, or doing a combination of removing and baffles that are in there with a dremel, as well as cutting out a larger opening in the bottom to allow more airflow would be helpful. If there is no hi-flow replacement filter available yet, just wack the box off and use a pice of stainless tubing form throttlebody to fenderwell with a conical hi-flow on the end, and fab up a heatshield. If you have a shop, or know a shop, they can be made much cheaper than what retail costs you.
ZYA_LTR is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
CAI vs Air Box rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 06-25-2009 03:32 PM
No "Show Signature" Box in Miscellaneous... RPO_Z28 Site Related Announcements / Suggestions / Feedback / Questions 10 06-20-2009 01:08 AM
Missing air filter on a 01 Cavalier jstein General Automotive + Other Cars Discussion 4 06-06-2009 10:33 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
