Old 02-25-2013, 08:57 AM   #1
516mike
516mike's Avatar
Drives: White 2012 2lt/rs convertible
Help-CAI Suggestions
I purchased my 1st Camaro back in the Spring, it's a 2LT/RS convertible. Found this site a few months back, and after exploring the site for a little while I figured it a good move to register (lot of great info especially for a newb). Anyway, I have been looking to swap out the air intake but I don't want to void any coverage offered through either the factory or the MPP extended warranty. I have been working with the dealership I bought the car from even though there are 2 other dealers closer due to customer service so far. When I asked about the cai options the parts department is pushing the Volant intake kit w/ the filter bag, he says it must be ordered and installed through them/his guy (cost after install $502 which is $100 cheaper than at closer dealers). I've noticed most of you suggest the CAI n K&B brand intakes. Also, if they do the add-on will I only be able to go through tis dealership if any problems occur in the future? Thoughts, opinions,etc....
516mike is offline   Reply With Quote
Old 02-25-2013, 10:55 AM   #2
HDRDTD
Just adding a CAi will notmally not void the warranty.
Just check with your local dealer and ask them. In some cases, the dealer will install it for you. Mine did.
Old 02-25-2013, 10:58 AM   #3
516mike
516mike's Avatar
The dealer said I have to purchase any upgrade through them or they will not install, also said would void warranty if done on my own n there was a prob...I will contact another dealer. How much did they charge you for install, if you don't mind me asking?
Old 02-25-2013, 11:00 AM   #4
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
All dealerships are going to be different. Some are more lenient than others, it just depends on the situation. I think for your standard intake you shouldn't have much to worry about, as it didn't stop me. Already 4000 miles in and I already have changed out most of the rear suspension and gone with coilovers and an exhaust.
As far as installation goes, doesn't take too long, roughly $100 or under would be a fair price for the job. Let me know if you need any further help!
ModBargains.com is offline   Reply With Quote
Old 02-25-2013, 11:42 AM   #5
516mike
516mike's Avatar
Is there tune needed when adding the CAI?
Old 02-25-2013, 01:55 PM   #6
HDRDTD
No idea since they were installing a whole list of things at the time.
BTW, yes I bought the CAI through the same dealer that installed it. They have a long standing relationship with CAI the company.
Old 02-25-2013, 01:55 PM   #7
HDRDTD
If it's just a CAI, then no tune is usually necessary.
Old 02-25-2013, 04:10 PM   #8
steveintulsa
steveintulsa's Avatar
Drives: 2010 rs/ss
You should find some good aftermarket shops around Phoenix to use (and probably the same one's are used by the dealers too) or check with Camaro Car Clubs in area. You deserve a better relationship than you are getting.
steveintulsa is offline   Reply With Quote
Old 02-25-2013, 04:34 PM   #9
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
we are local for you and would love to help you out and save you a ton of money over the stealership!!!
Joe@CPR.com is offline   Reply With Quote
Old 02-25-2013, 06:38 PM   #10
516mike
516mike's Avatar
Thanx, I appreciate all the info!!!!
Old 02-25-2013, 07:43 PM   #11
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
No tune needed on the CAI.
Contact Matt at Midway or Rick at Courtesy Chevy, they are both mod friendly dealers.
PM me if you need more info on them, they both do excellent work. Check them out on the Arizona All Gens Camaro Club forum and website.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 02-25-2013, 09:28 PM   #12
GnyaTek
GnyaTek's Avatar
Drives: 2011 SIM 2SS/RS Vert
Hafta say that I REALLY like the CAI brand intake... and no tune needed and most dealers have no issue with warranty on the rest of the engine/drivetrain with one installed.
I noticed that you were looking to have it installed by a shop? The CAI intake is SUPER easy to install ... if you can use a screwdriver and a socket wrench, you have the skills needed and it should take 20-30 minutes total (or I am sure there are some Camaro5 folks there in your area that you could talk with about it if you needed moral support (check the regional forums for a local club).
GnyaTek is offline   Reply With Quote
Old 02-26-2013, 02:11 AM   #13
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
A tune will void the warranty.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 02-26-2013, 12:46 PM   #14
Steeler NY
Steeler NY's Avatar
Drives: 2011 2SS/RS IBM Vert
516 Mike,
I have a CAI on a SS but im sure it ia as easy to install on an LT. I agree with GnyaTek it should take no longer then 1/2 hour to install in your driveway. you can also contact the guys at CAI (go to there website) they are very helpfull. I bought mine from another member and the guys at CAI hoohed me up with a hose i needed. there is no tune needed.
Good luck!
Steeler NY is offline   Reply With Quote
